Author Topic: Whats the name of Bar used to tighten wheel  (Read 2021 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 27 January 2011, 11:07:51 »
It,s the long one that clicks when it,s tighten then up to the right amount. And where would be best  to get one.
Thanks
Steve.  :y
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
Re: Whats the name of Bar used to tighten wheel
« Reply #1 on: 27 January 2011, 11:19:45 »
A torque wrench/bar.
Most motor factors or even Halfords sell them.
SP_3.2
  • Leicester
« Reply #2 on: 27 January 2011, 12:13:07 »
Thanks  :y
V6 CDX-er
  • Sheffield
« Reply #3 on: 27 January 2011, 19:47:23 »
Those Halfords ones are pretty good IMO. Calibrated to within 1% as well.
well worth spending a little extra on one of those as opposed to something cheaper, (and not as accurate).
ballcock50
  • South Wales
« Reply #4 on: 27 January 2011, 20:17:58 »
Pactical Performance Car magazine did a product test in the last mag with the Norbar Tru Torque coming top and the Halfords professional coming second. :y
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #5 on: 27 January 2011, 20:50:26 »
That's  right I've had 2 Norbars for years 1 ranged from 30 to150nm and 1 from 8 to 54nm also have a Franklin 43 to 348nm mostly for suspension and wheelbearings
Bent valve
« Reply #6 on: 27 January 2011, 23:49:50 »
You dont use a torque wrench to tighten a wheel, you need a wheelbrace, or one of those extending bars :y
« Reply #7 on: 28 January 2011, 00:00:09 »
but if you want to tighten it to a specific torque (110 ftlb?) how are you going to do that with an extending wheel brace?  ;) ;) ;)
tidla
  • solihull
« Reply #8 on: 28 January 2011, 00:02:01 »
two clicks of the elbow. ::) :y
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #9 on: 28 January 2011, 00:05:46 »
You might not use a torque wrench, but it is good practice to use one and I always do.  If I see a tyre depot not using a torque wrench they get crossed off my list of places to use.
Alan
« Reply #10 on: 28 January 2011, 00:07:09 »
which is generally how I do it, but Steve wanted to do it properly.  :y :y :y
As long as you don't extend the brace when you tighten.  :y :y
« Reply #11 on: 28 January 2011, 00:09:57 »
That depends whether they use it after they've tightened your nuts up (ooooer  ::)) to zillion ftlb with their windy gun first.  :-? :-? ;D ;D
tidla
  • solihull
« Reply #12 on: 28 January 2011, 00:16:49 »
yep, tis true. nowt worse on the hard shoulder on a rainy day trying to undo wheel nuts that tightened to the same spec as the forth bridge
