Author Topic: Oil pressure lost on oil change  (Read 1448 times)
Jan-Erik
« on: 28 January 2011, 09:11:48 »
Hi.
I can use some help.
A friend was canging oil on my car. After the job there was no oil pressure in the engine. At least not in the headers. they are making a lot of valvenoise. New filter and oil. Is it the oilpump or can it be somthing else? Thevalve next to the filter has been changes with no result. Even tried a second filter.
the car in question are 1996 2.5 V6 CD X25XE
Re: Oil pressure lost on oil change
« Reply #1 on: 28 January 2011, 09:19:07 »
What oil did you use, and how much did you put in?  (where is it on the dipstick now?)
Jan-Erik
« Reply #2 on: 28 January 2011, 09:26:16 »
The oil is right on max on the dipstick. The oil is mobile 5w40
I am in norway ( cold )so that was the recommandation.
Thanks for answering :)
« Reply #3 on: 28 January 2011, 09:35:07 »
Was a flushing agent added to the engine before teh old oil was drained?
« Reply #4 on: 28 January 2011, 09:36:11 »
.... After the job there was no oil pressure in the engine.  ...
Did the oil pressure light go out?  :-/
Jan-Erik
« Reply #5 on: 28 January 2011, 09:46:15 »
No flushing agent and the warning lamp did not go out. I have not messured the pressure since there clairly is none.
« Reply #6 on: 28 January 2011, 10:36:23 »
It sounds like the oilchange perhaps dislodged some 'gunk' that's now been sucked up and is blocking the oil pickup in the sump, to me..
Probably worth pulling the sump off and checking the pickup - if I recall, on the 2.5s, that's quite easy as you only need to pull the rearmost sump on the engine..
Jan-Erik
« Reply #7 on: 28 January 2011, 11:02:23 »
It has been removed and checked. But not by me so it can be worth checking...
Do anyone know if threre is a general problem with theese cars. I am an mechanic and had never had this problem with the omega before. I got the car for nothing bc of this problem.
« Reply #8 on: 28 January 2011, 11:08:43 »
AHHH .. so slightly different ... Am I right in saying there has never been oil pressure since you got the car ?? There was no oil pressutre BEFORE the latest oil change ??
Jan-Erik
« Reply #9 on: 28 January 2011, 11:23:52 »
Nope it was working perfectly bf the oil change. Since it was not done by me I am a little baffeld on how it can dissappear bc of an oil change...:)
« Reply #10 on: 28 January 2011, 11:33:23 »
Oil pressure relief valve sticking?
Abiton
« Reply #11 on: 28 January 2011, 11:51:43 »
Was the oil change performed via the sump plug, or the dipstick tube/vacuum extraction?
Jan-Erik
« Reply #12 on: 28 January 2011, 12:18:54 »
This is new...
Jan-Erik
« Reply #13 on: 28 January 2011, 12:19:24 »
Sump plug..
Page created in 0.047 seconds with 20 queries.
