Author Topic: abs ecu  (Read 3092 times)
rossi123
  • St Helens Lancashire
Re: abs ecu
« Reply #15 on: 28 January 2011, 13:35:15 »
 I'd of thought The Boy would of said so I don't think it should be a problem Because he was asking the questions to the fella I bought it off as a matter of fact I'd sooner go down to see him but can't get in touch think he might be away or something
rossi123
Re: abs ecu
« Reply #16 on: 28 January 2011, 13:38:44 »
BBA REMAN haven't got back to me yet so don't know that one but I'm sure it was the same part no but now I'm worrying, if this fails it's going ive had enough of it FFS
Re: abs ecu
« Reply #17 on: 28 January 2011, 14:09:28 »
remind me, what year is your car?
rossi123
Re: abs ecu
« Reply #18 on: 28 January 2011, 14:30:43 »
2001 facelift model 3.0
Re: abs ecu
« Reply #19 on: 28 January 2011, 14:50:41 »
My EPC shows 3 different ABS ecu's fitted to 3.0's (and 2.5's)
90444662 pre facelift
90541367 mini facelift
9117171 - facelift
A different part number was used for the 3.2 / 2.6's -
9198884 - no ESP
93172448 - ESP (unlikely to be seen in UK)
TIS seems to suggest some of the 3.0's could have canbus, but Im probably reading it wrong.
Unfortunately VIN filtering doesnt work for me, so cant reference which of those was your original, but would expect it to be as the descriptions above.
rossi123
Re: abs ecu
« Reply #20 on: 28 January 2011, 15:01:17 »
Do yu think it's worth going over there then or to put it differently do you think it will work
MutantCav
  • Gainsborough
Re: abs ecu
« Reply #21 on: 28 January 2011, 15:29:53 »
From memory of stripping a lot of Omegas the ABS/ECU part number ends in 206 and is the same for mini facelift 3.0 and facelift 3.0 engines...
Re: abs ecu
« Reply #22 on: 28 January 2011, 15:30:15 »
Honestly no idea, Mark is far more knowledgable, and tech2 aware, and I read his post as suggesting it wont work.  EPC / TIS doesnt say it will, or wont, but an underlying suggestion of it wont as different parts, and I dont know if anyone has actually tried getting this combo to work.
Whether a CAN ecu can 'downgrade' to the old system I dont know.
What are your current symptoms?  TC light on?  does the speedo etc work?
rossi123
Re: abs ecu
« Reply #23 on: 28 January 2011, 17:50:03 »
Speedo works fine, cruise control fine , starting and revs fine the probs are rev counter up at top and it's not the smoothest at the moment but that seems to be all that's up oh and the Tc light is on but that's it
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: abs ecu
« Reply #24 on: 28 January 2011, 17:52:33 »
We had this a while ago as i remember 2.5 & 3.0 are inter changeable, 26 & 3.2 are inter changeable but not 2.5/3.0 with 2.6/3.2.
rossi123
Re: abs ecu
« Reply #25 on: 28 January 2011, 18:30:20 »
Thanks Daz at least i know now suppose I'm gonna have to get another then don't supposeyou know of any mr looneee
