Author Topic: Now its just taking the mick!  (Read 2219 times)
Malcolm_D
  • York
  • It shines!
« on: 21 January 2011, 22:34:17 »
 98 2.5 - water in plugs 4 & 6, big misfire, sorted this but then wouldn't start, tried new crank sensor, petrol present also spark. Turned out to be failed coil pack, started as soon as new one put on  :). Cleaned out breathers while I was at it, took care putting it all back together, sealed scuttle, everything fine. A bit noisy at the top end at first but is always has been and it hasn't been running since mid December.
Took her to work yesterday, ran great there and back, top end noise soon stopped. Started her again 10 mins after getting home and a misfire has appeared! Not there when revs increased gently with car stationary, but it appears if reved quickly. Certainly present when she is driven.
Off now to dig a big hole in my garden so I can bury her!  >:(
JasonH
Re: Now its just taking the mick!
« Reply #1 on: 23 January 2011, 08:12:47 »
I' suspect your HT leads. About £40 for a set of Bosch ones but  bugger to fit  :(
« Last Edit: 23 January 2011, 08:12:58 by JasonH »
« Reply #2 on: 23 January 2011, 10:46:58 »
It it was mine I'd change the plugs first, if not done already, then see if that cures it. If not, only leaves plug leads, which means undoing your scuttle again.   :(
OmegaGav
  • Hemel Hempstead
  • For god sake doooo something !!!!!
    • 08' Vectra 3.0 V6 Cdti
« Reply #3 on: 23 January 2011, 12:59:01 »
Ditto  :y had the same problem with mine and it was an HT lead that had a crack in the plastic on top of the plug and was arcing out on the engine !!
And it had to be No6 the worst one to get to  :o
Yes it's my M&S goulash cannon. Ready Aim Fire...!!!
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #4 on: 23 January 2011, 15:05:18 »
Yep...Flubbered coil pack normal kills HT leads and plugs...certainly did on mine.
Changed the lot, problem went away.
Malcolm_D
  • York
  • It shines!
« Reply #5 on: 23 January 2011, 16:29:12 »
Hmmmm.... tough choice, do I continue digging the hole or replace the leads and plugs? If I do the plugs and leads it will have to be when SWMBO is out, she is already on the warpath due to the amount of time I spend under cars! Can't blame her, I am getting a bit fed up of being cold, damp and smelly myself!
Thanks for the advice guys, anyone know a good marriage counsellor?  ;)
PS no codes which would point towards plugs and leads?
OmegaGav
  • Hemel Hempstead
« Reply #6 on: 23 January 2011, 16:33:42 »
Nope  :( No codes with my lead problem :'(
Try removing the leads and checking for damage before deciding what to do :)
Malcolm_D
  • York
  • It shines!
« Reply #7 on: 23 January 2011, 16:35:41 »
Have given them a once over already - nothing obvious but I will check again. Cheers  ;)
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #8 on: 23 January 2011, 16:47:53 »
You have my sympathy. My 2.5 drove me to distraction with endless problems.
Try having a look under the bonnet in the dark for plug lead arcing. My last misfire was number 5 lead.
Malcolm_D
  • York
  • It shines!
« Reply #9 on: 26 January 2011, 23:10:33 »
Which HT leads? Do I buy from VX dealer (have TC card but would have to go through to Leeds), anyone know where I can get Bosch ones from or do I go to my trusted factors and buy the ones they have?
Advice please  ;)
Neil_MV6
  • Sutton Coldfield-West Midlands
« Reply #10 on: 27 January 2011, 14:50:54 »
  Not there when revs increased gently with car stationary, but it appears if reved quickly. Certainly present when she is driven.(
I had exact same symptoms recently, I changed the plugs and the problem was resolved.  :y
M Kerr
  • Birmingham
    • 2.5 GLS Omega, X Type
« Reply #11 on: 27 January 2011, 23:07:32 »
My codes didn't point to it either but it was the HT leads.  Good advice to look under the bonnet whilst running in the dark.  It could point you exactly to the problem and only takes a minute. SWMBO can't complain too much about that...
I bought leads following the reply below from Jampy  Supplied in a couple of days.  No problems
Sorry the link doesn't seem to be working but paste into your browser and presto!
Hope this helps  (these are V6) :y
Newbie
Offline
Daventry
Gender: male
Drives: Omega 2.0 Auto
Re: Misfire and fault codes
My Bosch leads cost £20.78 plus £4.49 postage from Powersparks on ebay.  The leads for your car would cost £39.95 plus £4.49 postage.  My leads were slightly longer that the originals but the extra allowed more slack at the Dis pack.  Your leads can be seen on this link:
http://cgi.ebay.co.uk/BOSCH-Silicone-Spark-Leads-VAUXHALL-OMEGA-2-5-3-0V6_W0QQit...
OmegaGav
  • Hemel Hempstead
« Reply #12 on: 29 January 2011, 11:17:09 »
Advice please  ;)
Got mine from local Europarts motor factors :y
About £60 if i remember correctly :y slightly longer than originals though :y
