Author Topic: Mv6 gearbox  (Read 1586 times)
bellers
Mv6 gearbox
« on: 27 January 2011, 22:00:03 »
Hi folks
Ive got my first problem with my omega :) havent pulled it apart yet to see which it is either propshaft or gearbox making a knocking and no drive :(
Im just looking to see incase ive to buy gearbox are all v6 boxes the same or will my mv6 box have a diferent ration?
Thanks
Jonny
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Mv6 gearbox
« Reply #1 on: 27 January 2011, 22:21:46 »
it could be the diff or driveshafts rather than the box,get someone to try it while you have a look underneath and see whats spinning and whats not
other rides
Re: Mv6 gearbox
« Reply #2 on: 27 January 2011, 22:27:50 »
Auto or Manual?
bellers
Re: Mv6 gearbox
« Reply #3 on: 27 January 2011, 23:09:13 »
forgot to say its manual
when i rev car the knock gets quicker and when im in below i can hear knock from where gearbox meets the prop
henryd
  • west cornwall
Re: Mv6 gearbox
« Reply #4 on: 27 January 2011, 23:14:15 »
ok but does the prop spin when car is in gear with clutch released
other rides
bellers
Re: Mv6 gearbox
« Reply #5 on: 27 January 2011, 23:40:14 »
Ill check tomorrow and let yas know. If its spinning will that hint towards diff. Even tho the knocking is from gearbox end?
bellers
Re: Mv6 gearbox
« Reply #6 on: 29 January 2011, 18:57:04 »
Started the omega today as i had to move it to make some room the prop shaft is turning and when i let the clutch out and lots of juttering from backend and a wee bit of drive
Audi_Paul
  • East Anglia
Re: Mv6 gearbox
« Reply #7 on: 29 January 2011, 23:07:20 »
Diff!
chuftsmv6
  • stoke on trent
    • omega mv6 2jz and audi s3
Re: Mv6 gearbox
« Reply #8 on: 30 January 2011, 23:25:22 »
hi i had the same problem i changed the diff first and it ended up being the gearbox as well i was gutted they both died the same time :'( :)
