Author Topic: 2.5 cambelt dogy belt  (Read 1035 times)
mowerman
  • bedfordshire
« on: 31 January 2011, 17:15:18 »
i think i have the wrong belt it came in a kit
the belt has a set of white and yellow markings non of which
line up with the pullys
i have another problem the left hand wedge came out and the pullys have spun out if timming has anyone els had this problem
Re: 2.5 cambelt dogy belt
« Reply #1 on: 31 January 2011, 17:29:47 »
You can normally find a set of markings on the belt that will work, but they can be fitted without reference to the markings if not.
If the cam timing has slipped, you need to rotate the crankshaft back (anticlockwise) to 60 degrees before TDC, rotate the cams back into alignment with the timing marks, lock them with the tool again, then bring the crankshaft back clockwise to the TDC position before locking its' position and fitting the belt.
« Reply #2 on: 31 January 2011, 19:27:06 »
I concur with Kevin Wood. Must rotate engine back ANTICLOCKWISE to avoid valce damage.
Chances of valve damage already?
« Reply #3 on: 31 January 2011, 19:36:56 »
Zero if the crank has not been turned
jiho102
  • Newmarket
    • 2.6
« Reply #4 on: 31 January 2011, 22:56:39 »
Hi.
   Had the same problem as you when i was changing my belt.
Following the DVD from here he was lining all the marks up but when i tried mine none of the marks on the belt were in the right plage even though the new belt was the same length as the old one.
Got my mechanic friend to have a look in case it was the wrong belt but he just fed it onto the pullys even though none of the marks were in the right place but everything worked fine. I think thats what years of experiance can do.
P.S got my belt from autovaux.
« Reply #5 on: 01 February 2011, 06:23:10 »
Done 6 or 7 v6 cam belts now, none of the belts had any timing marks on them.
Seems to me it's one more thing to have to line up.  :-?  It makes no odds what belt teeth sit on what mark and it's all to cock after a revolution anyway.
Really wouldn't worry about belt marks IMO.
« Last Edit: 01 February 2011, 06:24:31 by chrisgixer »
