Author Topic: Creaking - new damper ?  (Read 1092 times)
bigdods
  • Brackley
« on: 01 February 2011, 16:55:53 »
I have a creaking noise coming from the OSF, sounds like an old bedspring. Creaks when I bounce the car on that corner. I guess its probably a new damper needed - at 160k on original dampers its not really a surprise.
Which dampers are people recommending now ? KYB ? And where is the cheapest place to get them from.
Is it worth replacing the springs at the same time ? I assume I can pick up springs from the same place that sells the dampers. Or are they coilovers and bought as a complete damper/spring unit ?
Is there any other possible cause for creaking ? I guess ARB or maybe the spring itself is damaged (will find out later in the week)
Cheers
Dodsy
« Last Edit: 01 February 2011, 16:56:53 by bigdods »
duggs
  • Felixstowe
    • BMW 3.0 Sport
Re: Creaking - new damper ?
« Reply #1 on: 01 February 2011, 17:09:46 »
Damper or wishbones ?
bigdods
  • Brackley
« Reply #2 on: 01 February 2011, 17:17:44 »
Hmm I was just thinking the same. The lemforders on there right now have been on for ~40k so could need doing again. In fact the more I think about it the more likely it is to be the wishbones.
Best place to buy them from ?
