Author Topic: Door removal  (Read 2335 times)
Jamatrad
  • Staffordshire
  • today is the start of your journey not the end
Door removal
« on: 31 January 2011, 12:12:22 »
I am attempting as a 'novice' to remove the doors off my 2.5 CDX. Is there a thread on the site showing this?
I've looked but cannot find
Jammy
« Last Edit: 31 January 2011, 13:22:31 by Jamatrad »
It is the journey not the destination that shapes your life
MutantCav
  • Gainsborough
Re: Door removal
« Reply #1 on: 31 January 2011, 12:27:19 »
Front doors unscrew the electric wiring connection...back doors pull the wiring out through the rubber near the sills and unplug...then eits just a matter of knocking out the 2 pins holding the door in place where the door hinges and undoing the screw holding the door retaining hinge in place...
Re: Door removal
« Reply #2 on: 31 January 2011, 20:03:39 »
BE CAREFUL
The doors are a lot heavier than you might think. Either enlist some one to help  and/or support the weight on blocks or something
Jamatrad
  • Staffordshire
Re: Door removal
« Reply #3 on: 01 February 2011, 08:55:11 »
Thanks guys
Do I knock the pins up or down?
Re: Door removal
« Reply #4 on: 01 February 2011, 08:58:59 »
Pins only go one way  due to the flared collar at one end ;) Fronts probably need supporting. Rears.........unplug connector @ bottom of B post, unbolt doorstrap, close door, hit the pins out then release door handle & lift door away
« Last Edit: 01 February 2011, 09:00:56 by RobG »
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Door removal
« Reply #5 on: 01 February 2011, 14:55:26 »
My rear door pins wouldn't budge leading to an interesting session with Mr Angle Grinder.....4 discs later the door was off in pieces ..literally
russ0205
  • northants
    • mondeo
Re: Door removal
« Reply #6 on: 01 February 2011, 15:34:42 »
Not sure thats the best way to remove them as the doors may need to be re used, :'(
r1
  • nottingham
Re: Door removal
« Reply #7 on: 01 February 2011, 16:07:35 »
use a trolley jack to support the door
Jamatrad
  • Staffordshire
Re: Door removal
« Reply #8 on: 01 February 2011, 19:21:40 »
Thanks guys I've got the picture........Get someone to do it for you who knows what they are doing  :-?
Jammy
Jamatrad
  • Staffordshire
Re: Door removal
« Reply #9 on: 05 February 2011, 10:49:20 »
Thanks for the tips guys.
The doors are off.
I had to cut the hinge adjacent to the body to enable the doors to be useable again.
The old girl is now down in the graveyard
Re: Door removal
« Reply #10 on: 05 February 2011, 15:03:12 »
The doors are off.
A bit drastic!!!!  :o
Why didn't you just remove the hinge pin? They're just a push/hammer fit and cost buttons (IIRC about 50 pence each when I replaced a pair)
Jamatrad
  • Staffordshire
Re: Door removal
« Reply #11 on: 05 February 2011, 17:47:48 »
Struggled with the hinge pin and I didn't want to belt them too hard!  :-/
Re: Door removal
« Reply #12 on: 05 February 2011, 18:10:13 »
I knocked mine the wrong way a touch just to get them to move. I made a bar with a 'fork' on the end to go over the flare then hit it with a big hammer.!  ;D ;D ;D
The easiest door pins I've ever replaced had broken into 3 bit, so the old pins were knocked out with the new (no flare on them though and the pins were out of the work's stores  ::))
« Last Edit: 05 February 2011, 18:12:13 by Andy_B »
Jamatrad
  • Staffordshire
Re: Door removal
« Reply #13 on: 05 February 2011, 21:39:27 »
Thanks Andy,
When the guy who picks the doors up reads this he should have no problems reinstating them
