Author Topic: rear noise  (Read 1471 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
rear noise
« on: 04 February 2011, 12:53:46 »
hi all
right my car has just started making a strange noise from the rear somewhere but only from cold and only when driven in reverse (manual box) it sounds like something rubbing or the sound a drying bearing makes, thing is it doesnt do it when warmed up or when the car is pushed,
i'm stumped  :-/
any help in what i should be checking  :(
thanks
iainb
  • West Midlands
Re: rear noise
« Reply #1 on: 04 February 2011, 13:58:18 »
Hi, I would check the exhaust mounting rubbers as when they ware you can get movement in the pipes.
Try pushing the exhaust from side to side and see if the systems just rubs on the dif....as mine did !
fiend61
  • york
  • each to their own
Re: rear noise
« Reply #2 on: 05 February 2011, 02:43:37 »
see where you are coming from iainb  ;) but it would do that going forward not just in reverse i would have thought also when being pushed would create the noise aswell  :-/
this only happens when cold and driven slowly in reverse  :'(
is there anything that could be 'drying' out  :question
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: rear noise
« Reply #3 on: 05 February 2011, 04:03:23 »
have you jacked up the rear with both wheels off ground and spin the wheels to check the dif???
Solar charger fitted.
If not Broke dont fix it..
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: rear noise
« Reply #4 on: 05 February 2011, 08:59:10 »
possibly hand brake shoes - seem to recall this on mine in the distant past
  • Auckland
    • Mazda MPV
Re: rear noise
« Reply #5 on: 05 February 2011, 09:44:13 »
Chances are that the handbrake actuator mechanisms have partially seized and aren't releasing straight away.
fiend61
  • york
  • each to their own
Re: rear noise
« Reply #6 on: 06 February 2011, 20:35:40 »
looks like a strip down and have a look then  :'(
thank god for the guides on here  :y
Re: rear noise
« Reply #7 on: 06 February 2011, 22:03:10 »
rear bushes come to my mind..
