Pages: [1] 2 3  All   Go Down
Author Topic: Locking wheel nuts  (Read 4535 times)
David Wilson
  • Sheffield, England
Locking wheel nuts
« on: 10 January 2011, 23:28:12 »
Does anyone know what locking wheel nut remover/removal socket and size you would need if you had the Vauxhall locking nuts and you couldn't undo them?
A friend said he could drill them but I don't fancy that as its going to be time consuming.  The normal nuts are 17mm and the locking nut key is really worn.
Thanks.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Locking wheel nuts
« Reply #1 on: 10 January 2011, 23:33:25 »
There are a couple of distinct designs, and further to that, there are several of each design.  You cant just provide a single locking wheel nut, else it wouldnt be very secure.
If you have the original key, it will have a code stamped on it.  Take it to Vauxhall and they will get you a replacement for not too much dollar.
millwall
  • se london
  • no muff too tuff
    • accord type s
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #3 on: 10 January 2011, 23:37:23 »
http://www.screwfix.com/prods/94826/Van-Car-Accessories/Mechanics-Tools/Laser-Emergency-Locking-Wheel-Nut-Remover-4-Pc
A good tool, but you still need to smash off the spinning collar (if the later type of locking bolt).  :y
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #4 on: 10 January 2011, 23:43:17 »
good point  forgot about the collar :y    otherwise a very good set i have used before and got the locking nuts off
skyblue
  • Bracknell
« Reply #5 on: 10 January 2011, 23:49:53 »
So thats how you get new tyres is it nick some poor buggers  wheels  ;) ;D
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #6 on: 10 January 2011, 23:56:06 »
correct :y  be fair im saving for a house move every penny helps ;D ;D
skyblue
  • Bracknell
« Reply #7 on: 10 January 2011, 23:59:03 »
;D ;D ;D Sorry David for hijacking ya question... the two fools will leave ya alone now ;) :)
« Reply #8 on: 11 January 2011, 00:04:00 »
The locking bolts initially fitted to my car were the 3 pin type. The collar was paper thin & very easily cut off, I used a very small home/work made chisel.
Halfords do a locking bolt remover too
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_196491_langId_-1_categoryId_165469
skyblue
  • Bracknell
« Reply #9 on: 11 January 2011, 00:09:27 »
Would a local scarp yard have one  by any chance  :-/
« Reply #10 on: 11 January 2011, 00:15:54 »
possibly, but would it be the correct pattern?  :-/ They are supposed to be a key for anti-theft.
I asked nicely at the local ATS and they removed mine for me  :y :y :y
skyblue
  • Bracknell
« Reply #11 on: 11 January 2011, 00:21:08 »
I was just thinking out aloud as i remembered the 3 pin job fitted mine + the brother in laws motor  hence why i thought they were a standard fit  :-/good shout abotut local ATS tho :y
« Reply #12 on: 11 January 2011, 11:04:52 »
If they are the Vauxhall cookie cutter ones then I feel sorry for you :'(
« Reply #13 on: 11 January 2011, 11:09:07 »
I've never had a problem with mine, maybe it's because they've rarely been touched by any tyre fitters. It was the previous 3 pin type I/Kwick Fit had problems with ie I ended up with a 2 pin 'key'  :(
« Reply #14 on: 11 January 2011, 11:21:37 »
I bought an MV6 a couple of years ago for its Irmscher body kit and wheels. It had cookie cutters on it and I suspect someone had tightened the nuts with an air gun, there was no way they were coming undone so I had to drill them, took me ages ;D
Pages: [1] 2 3  All   Go Up
