Author Topic: Poor Heating  (Read 866 times)
robo MV6
  • Orpington, Kent
Poor Heating
« on: 06 February 2011, 20:19:31 »
My MV6 face lift 2000 model heating never reaches a sensible temp even when the control is set to high.  I have had the heating pipes looked at by a mechanic who reckons that there is no problem with the matrix and all pipes are hot. The air con works well! :-?
Anyone else had this problem and found a cure?
robo
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Poor Heating
« Reply #1 on: 06 February 2011, 20:21:20 »
Does the engine heat up normally? Temp meter raising to the middle of the scale and stays there? If not, you've got a stuck stat.
robo MV6
  • Orpington, Kent
Re: Poor Heating
« Reply #2 on: 07 February 2011, 20:45:16 »
Yes the temp is showing normal range and stays in middle!
