Author Topic: Car seems to be running cold in cold weather  (Read 3309 times)
shell
  • Glasgow
« on: 08 February 2011, 21:00:08 »
Hi all, My car has always tended to over heat although this has usually been manageable. Recently in cold weather, I have noticed that the temp gauge seems to go right down, almost to the very bottom, especially at speed, on motorway trips.
Could this be a stuck thermostat?
Thanks Shell.
Re: Car seems to be running cold in cold weather
« Reply #1 on: 08 February 2011, 21:08:25 »
It should sit in the middle of the gauge for motorway cruise, being facelift that would be 85, its fairly common for V6 to get a sticking stat. There is a guide in the maint section, if your handy with a set of spanners  :y
shell
  • Glasgow
« Reply #2 on: 08 February 2011, 21:13:21 »
I'm no good with spanners. any idea how much it may be for a garage to replace the thermostat?
Thanks again.
shell.
« Reply #3 on: 08 February 2011, 21:13:28 »
Easy way to check the 'stat
Start engine from cold and leave to idle. Stand with one hand on the large top pipe from the engine to the radiator .. the one that comes from the 'stat to the radiator.
This should remain cold and then get a sudden surge of HOT water as the 'stat opens.
If the pipe slowly and gradualy warms up as the engine warms .. the 'stat is stuck open
HTH  :)
« Reply #4 on: 08 February 2011, 21:15:59 »
its fairly common for V6 to get a sticking stat.  .....
Phew!!! Back to normal!  ;D ;D
Since when was it normal for a V6 'stat to stick?  ;D ;D ;D ;D
I suppose I'd better change mine then .............. I've never even seen my stat in 7 years  ;) ;) ;)
shell
  • Glasgow
« Reply #5 on: 08 February 2011, 21:16:10 »
Thanks Entwood, I will try that tomorrow to be sure.
cheers,
shell.
« Reply #6 on: 08 February 2011, 21:17:54 »
..... any idea how much it may be for a garage to replace the thermostat?
Lots! The stat is buried in the the middle of the engine so isn't the 5 min job it is on other cars/engines.  :(
« Reply #7 on: 08 February 2011, 21:20:41 »
and there are one or two "awkward" bits that can bite and make the job a lot longer ....  The Transfer Pipe and the B*******d Bolt come readily to mind .....  ( I'm SO glad I paid DLK/EP to do mine ...   :)  )
« Reply #8 on: 08 February 2011, 21:22:15 »
I would also prefer to pay instead of messing with bas***d bolt ;D
shell
  • Glasgow
« Reply #9 on: 08 February 2011, 21:25:32 »
Thanks Andy, its probably not a viable repair then, will that do any other damage to the engine? or can I sort of live with it? The car is really on its way out, but don't want to give her up until necessary.
Thanks again.
Shell.
« Reply #10 on: 08 February 2011, 21:28:49 »
Thanks again.
Shell.
you will consume more fuel, and cats will face unburnt fuel which can cook them..
« Reply #11 on: 08 February 2011, 21:36:15 »
Right then you.....  ;D
I've had to do the stat on all 3 of our Omegas, the 2.2's went at approx 100k and 9 years, Mother T's 3.0 Elite failed at about 85k and 9 years
I did say fairly.....  ::)
shell
  • Glasgow
« Reply #12 on: 08 February 2011, 21:37:21 »
OK, thank you, to all of you, for brilliant help and advice!
This forum has already kept my car going many times, and has saved me a small fortune.
I'm grateful to you all! I guess the writing is on the wall for my old mig, but I will persevere with her for a few miles yet.
Cheers Shell.
Dave Elite
  • Ellesmere Port
« Reply #13 on: 08 February 2011, 21:49:34 »
I found the job fairly easy to be honest when I did mine. The ba....d bolt was not the ba....d I thought/and was told it would be. Not too bad at all, I couldnt work out what all the fuss was about to be honest.
« Reply #14 on: 08 February 2011, 21:58:52 »
your hands must be tiny or you had  a lucky day ;D
seen many mechanics having trouble with it..
