Author Topic: Windscreen washer nozzle removal P/fl  (Read 4217 times)
iainb
  • West Midlands
« on: 08 February 2011, 10:47:53 »
Im trying to remove and clean the nozzle and have tryed to follow the Haynes instructions, but all I have managed to do is scratch the under side of the bonnet.
Haynes says disconnect the wiring and supply hose,depress the tabs at the rear of the body and remove upwards.
Well that dont work.
Anyone got a fool proof method of removal
Thanks Iain
Re: Windscreen washer nozzle removal P/fl
« Reply #1 on: 08 February 2011, 10:53:20 »
whats actually wrong with the washer jets/nozzle? the are usually fine, I use a small pin from a sewing hit to angle the jets, which also cleans them. If its a lack of pressure, take the pump out on the screen wash tank, there is a gauze in there which often gets bunged up and causes poor flow.
Apart from popping off the feed pipe, there should be no need to remove the nozzle.  :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #2 on: 08 February 2011, 11:01:55 »
Well I had the same problem on my 97 2.5 with heated nozzles. The total lack of flow was down to an internal blockage which I never managed to cure. The device has a 90 degree bend inside from memory.
I "cured it" by fitting a s/h one from a forum breaker. From memory it is held on by some form of clip under the bonnet.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #3 on: 08 February 2011, 11:02:21 »
I seem to recall the Senator had them on the bonnet surface and I used to reverse-flush them by pressing a garden hose over the nozzles.  Might need to warm the hose end first to allow it to flair. And disconnect the feed under the bonnet to let the water out!
I found that using a pin sometimes pushed foreign objects (crud) back into a cavity from which they would sneak to re-block the nozzles.  Generally the best way of re-setting the nozzles though.
Sorry not to answer the original question.  I have F/L. ;)
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
« Reply #4 on: 08 February 2011, 11:11:32 »
Well that dont work. .....
That's pretty much it. I thought I had a photo some where of one ........ but it appears not.  ::) Do one side at a time, it does work. I'd suggest a kettle of boiling water poured over the tubing before you try to pul it of each nozzle or there's a good chance you'll break something while everything is cold & brittle.
As Tunnie says, if you've a lack of water from the nozzles, it's a good bet that the filter that the pump sits in is blocked. Have a look here.  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152616577
found it  :y
« Last Edit: 08 February 2011, 11:15:56 by Andy_B »
iainb
  • West Midlands
« Reply #5 on: 08 February 2011, 11:57:22 »
Thanks for the tips.
What my problem is is reduced flow to the drivers side jet and yes I have used a needle to try and clear it.
When I press the washer button I get a short squirt from the jet and then it dribbles across the bonnet although the near side works fine with good flow.
I think im going to have a go at reverse flushing before risking breaking the thing off :y
« Reply #6 on: 08 February 2011, 12:30:55 »
I'd be looking at the pump filter at bottle. IMO you have apressure problem,  not a blockage  :y  :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #7 on: 08 February 2011, 19:21:38 »
I need to flush out my tank as the rubber gauze filter is alway blocking up.
I get a reduced power jet on the passenger side and a pathetic dribble on the drivers side.
Seeing as the tank filter is the easiest to do, I'd also say check that first.  :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #8 on: 08 February 2011, 22:16:06 »
If you are convinced it's the jets, you could get a couple from a breaker on here, or even fit some Insignia ones.  ::)
« Reply #9 on: 08 February 2011, 22:34:01 »
... or even fit some Insignia ones.  ::)
Not to a prefacelift, unless you have moved the washers like mine.  ;) ;)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #10 on: 09 February 2011, 21:57:39 »
Removed and flushed out my washer tank/bottle this afternoon.  Both jets now back to full blast.  :y
« Reply #11 on: 09 February 2011, 22:00:21 »
You actually removed the whole thing? :-? It seemed like too much effort to me, I just removed the pumps form the bottle & shoved the hose pipe into the filler pipe and flushed it that way.  ;) ;) ;) ;)
Agemo
  • Cleethorpes
  • Insignia
« Reply #12 on: 09 February 2011, 22:12:32 »
DOH! Yes, good point, just testing  ::)
Glad you're sorted Turk.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #13 on: 09 February 2011, 23:20:11 »
Tried that a few months back, but it didn't sort it on mine.  :(
Top tip if trying this method: Do not shove hose into filler pipe, turn on water and then remove the pump....with face directly above.
This I can advise against through personal experience. :-[ [size=14]
SPLOOOSHH !!! [/size]
[/font]:o :o :o :o :o    :-[ :-[       ;D
« Last Edit: 09 February 2011, 23:27:47 by Turk »
iainb
  • West Midlands
« Reply #14 on: 10 February 2011, 13:57:20 »
Update !
I found that the supply hose has a join by the PAS bottle which I seperated.
I then got my hose pipe and held it on the washer jet and got MrsB to turn on the tap, after a few seconds it started to flow back through the pipe I then did the other jet and had good flow.
I re joined the pipe and now have working screen washers on both sides.
The drivers side will need another blast to equal the other side flow rate.
So thank you all for the tips. :)
Iain
