Author Topic: Rusty Exhaust Tips....  (Read 2637 times)
twiglet
  • Norwich, Norfolk
« on: 09 February 2011, 15:27:02 »
I'm fed up of looking at the rusting exhaust tips on my F/L 3.2 Estate!
Trouble is, apart from the tips, the exhaust system is sound, and is nowhere near in need of replacement!
So I'm thinking that some nice chrome tailpipe trims would be a low-cost option to smarten things up! However, I DO NOT want it to look tacky or chavvy in any way, some ideally the design would be a close to the non-rolled end, slash cut profile of the OE pipes.
Just wondered if anyone had any advice or recommendations on where I might get such things??
Thanks in advance!  :y :y
sandune
  • Essex Southend
    • 2.6 Omega Auto
Re: Rusty Exhaust Tips....
« Reply #1 on: 09 February 2011, 15:33:07 »
Halfords :y
Omega_Dan
« Reply #2 on: 09 February 2011, 15:39:32 »
http://www.extremeautoaccessories.co.uk/products.php?section=1172
Have a look here. Not the cheapest but very good quality. 20th one down pretty sure that tip is almost identical to the omegas. Only downside is you will need 2! ;)
Dan
Dave Elite
  • Ellesmere Port
« Reply #3 on: 09 February 2011, 15:41:27 »
Dan
That would be 50 rather quid!
Omega_Dan
« Reply #4 on: 09 February 2011, 15:43:08 »
Dan
yup. Thats the only downside. other than that its a cheap jobby from halfords.
« Reply #5 on: 09 February 2011, 15:47:41 »
I got some chrome trims very cheap from Aldi/Lidl. Think they were £7. They still look fine. They would still look fine if I cleaned them.
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #6 on: 09 February 2011, 16:04:08 »
Interesting! I bought a genuine VX rear box over 3 years ago and the twin tailpipes appear to be stainless steel and they certainly haven't rusted.
« Reply #7 on: 09 February 2011, 16:24:46 »
You must have got one of the last proper ones like me, ones you get from GM now are no better than KiwkFit  :(
« Last Edit: 09 February 2011, 16:25:02 by tunnie »
Bent valve
« Reply #8 on: 09 February 2011, 17:55:58 »
What I did with mine, was to sand off all the rust and brush paint  on 2 coats of galvafroid zinc rich primer, which is a thick, high build anti corrosive paint that actually does what it says on the tin, followed by a light sanding to erase the brush marks, followed by 2 coats of halfords satin black spray.
No need for the satin black to be heat resistant, as the tailpipes do not get hot enough.
18 months later, and all is OK :y
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #9 on: 09 February 2011, 18:24:21 »
LongLife and Powerflow do their own range of exhaust tips to suit customers preference. Probably costly though. Not sure if they would sell just these and no idea of cost but it might be worth a look. They may do one that will slide over your existing tips quite snugly. Only downside is that they are intended to be tig welded on but I'm sure you'd sort something out. You should be able to view the available tips on their website. :y
« Reply #10 on: 09 February 2011, 20:13:41 »
got a cheapy off ebay - £7 - fits ok and chrome still ok after a hard winters salt!!
Agemo
  • Cleethorpes
  • Insignia
« Reply #11 on: 09 February 2011, 23:09:55 »
Ebay gets my vote too, 764 results under "Chrome tailpipe."  :y
Bent valve
« Reply #12 on: 09 February 2011, 23:41:45 »
I thought the OE boxes had rolled ends?
twiglet
  • Norwich, Norfolk
« Reply #13 on: 10 February 2011, 13:12:15 »
Thanks everyone for your help and advice.  I shall continue my search..
I have spent quite a bit of time looking on ebay, but haven't been able to find any that match the OE design.  The Aldi/Lidl option sounds interesting though... Cheers KW!
I might give the a rub down and repaint in the short term... Just need someone to write a how2 on how to remove a F/L estate rear bumper (I think the current how2 is for a pre F/L).
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #14 on: 10 February 2011, 15:18:48 »
The trouble with the Aldi & Lidl offers is they are only on for a few days and they usually sell out very quickly. If I recall correctly the tailpipe trims were an Aldi product. It might be worthwhile giving them a bell to see if they have any in stock.
