Author Topic: torque settings  (Read 1362 times)
ianboyo
  • Somerset
torque settings
« on: 10 February 2011, 19:30:50 »
hi is there a thread on the torque setting for all the engine componants for v6 can anyone help thank you
Re: torque settings
« Reply #1 on: 10 February 2011, 19:35:21 »
Here you go mate  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1156365122
ianboyo
  • Somerset
Re: torque settings
« Reply #2 on: 10 February 2011, 19:46:08 »
thanks for the settings  :y
Re: torque settings
« Reply #3 on: 10 February 2011, 19:53:04 »
I was only the 'Gopher', the Thanks go to Mr Marks DTM Calib who very kindly did the hard bit! :y
  • Auckland
    • Mazda MPV
Re: torque settings
« Reply #4 on: 10 February 2011, 21:23:54 »
Just curious
What do notes 1,2,3,4,5 & 6 say?
Is it something important..............?
Re: torque settings
« Reply #5 on: 10 February 2011, 21:30:06 »
The notes are :
1) Use new bolts.
2) Insert bolts with bolt locking compound (red).
3) Use new nuts.
4) Clean thread and insert bolts with bolt locking compound (red).
5) Use new copper seal rings.
6) When re-using oxygen sensor, coat thread with special grease (black).
7) Tightening to 10 Nm is performed after 10 minutes for the old version (without additional bore) and only after assembly of the complete toothed belt drive for the newer version.
8) Clean thread of fastening bolts and insert with bolt locking compound (red).
9) Tightening to 20 Nm is only performed after installation of the lower alternator fastening bolt.
10) Before assembly, coat thread of screw-on port with assembly paste (white).
11) In three stages of 90° each.
12) Retightening not required
Perhaps these need adding to the post in the guide ??  or is my list in TIS different to the one Mark used ??
« Last Edit: 10 February 2011, 21:31:08 by entwood »
Ploppy
  • Norfolk
Re: torque settings
« Reply #6 on: 11 February 2011, 05:55:05 »
Just wondered if anyone had the torque settings for spark plugs, oil sump plug, oil filter , rear brake discs/ calipers and wheel bolts for the 3.2 V6?
Thanks
Ploppy :y :y
