Author Topic: v6 auto torque converter  (Read 1930 times)
omegabsw
  • Essex
« on: 10 February 2011, 23:32:30 »
How hard is it to remove once the engine is out? any special tools/brute force?
sassanach
  • trowbridge
Re: v6 auto torque converter
« Reply #1 on: 10 February 2011, 23:38:20 »
just pull!!! :y
omegabsw
  • Essex
« Reply #2 on: 10 February 2011, 23:41:47 »
just pull!!! :y
I can do that!  :y
sassanach
  • trowbridge
« Reply #3 on: 10 February 2011, 23:43:05 »
you leave the tc behind on the gearbox when you remove the engine....and it just pulls off :y
omegabsw
  • Essex
« Reply #4 on: 10 February 2011, 23:48:53 »
Thats blinding to know, cheers.
I removed a bmw V8 once and the TC was still on the lump
sassanach
  • trowbridge
« Reply #5 on: 11 February 2011, 00:03:35 »
ahhh i see your boggle, you need to undo four bolts holding the tc to the flexplate,easily axcessed thro the hole in the lower bellhousing,rotate engine untill each bolt lines up in the hole and remove.
omegabsw
  • Essex
« Reply #6 on: 11 February 2011, 00:08:36 »
On the bmw right? not the omega
2woody
  • Northumberland
« Reply #7 on: 11 February 2011, 09:18:03 »
hole there on Omega, too.
T/C can come out with the engine, but MUST go in separately.
erubus
  • blairgowrie
« Reply #8 on: 11 February 2011, 09:41:28 »
sorry to slighty hijack, but i just did an engine swap and bolted the tc to the engine before putting the engine back in.  is thislikely to cause problems?
« Reply #9 on: 11 February 2011, 10:09:04 »
There is a danger that you'll damage the bushing and oil seals that support the torque converter nose in the gearbox or, worse still, it won't engage fully with the autobox oil pump and you'll crush the torque converter as you tighten the bell housing bolts.
If you assemble the TC to the gearbox you can be sure that it has engaged and slid fully in before offering up the engine.
erubus
  • blairgowrie
« Reply #10 on: 11 February 2011, 11:15:46 »
hopefully i'll be ok then, as the car has been driven since and isn't leaking fluid.  thanks for the info.  hijack over
« Reply #11 on: 11 February 2011, 11:16:58 »
Yep, you got away with it. :y
