Author Topic: Pressure in the Expansion tank  (Read 1130 times)
EXD
« on: 12 February 2011, 22:02:07 »
Hello
Is it normal that the water bouble's up when you lift the cap to the expansion tank, if the engine's hot and the engine is idling?
Its like some kind of pressure in the system?
Can it be air in the watersystem...?
Re: Pressure in the Expansion tank
« Reply #1 on: 12 February 2011, 22:06:15 »
Hello
Yes it is, that's why the cap has a warning on it!  ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 12 February 2011, 22:11:47 »
pressure cap keeps cooling system at approx 15psi to raise the boiling point of the coolant,if you remove the cap when hot and engine running you get instant boil up as pressure is lost.
other rides
EXD
« Reply #3 on: 12 February 2011, 22:22:29 »
OK, thanks you guys
