Author Topic: car doesnt feel right  (Read 3479 times)
the_omega_man
  • callington,cornwall
« on: 06 February 2011, 21:54:56 »
my omega doesnt feel right at the moment, like the steering is really vague and wandery on straight roads, replaced front drop links as they were banging over bumps and changed track rods as it failed mot on these. also when accelerating hard gear changes seem to throw the car around. any ideas? :-?
davethediver
  • Blackburn, Lancs.
Re: car doesnt feel right
« Reply #1 on: 06 February 2011, 21:57:04 »
Have you ckecked the condition of the wishbone bushes, how old is the rest of the suspension and what state are the tyres in?
Also after the work you have had done how was the geometery set up afterwards :question
« Last Edit: 06 February 2011, 21:57:47 by davethediver »
P.A. Caron de Beaumarchais
the_omega_man
« Reply #2 on: 06 February 2011, 22:06:26 »
got brand new shocks and coils on the rear, new front tyres 6mm tread on rear tyres. havnt had the tracking done yet and havnt checked wishbones there was no advisery on the mot so assumed theyed be ok
davethediver
  • Blackburn, Lancs.
« Reply #3 on: 06 February 2011, 22:17:09 »
Assuming you didn't put falken tyres on (just for you chris) i would be checking the wishbone bushes and then looking at having a full geometry setup done at WIM or one of its partners. Don't waste yourmoney on just traking :y
SJKOO01
« Reply #4 on: 06 February 2011, 22:22:02 »
Without sounding insulting, as it's not meant to come across as that way.
With the car stationary, have you put wheels pointing stright ahead, then move the steering wheel side to side about an inch or two, to see if the front wheels move about the same amount, or if it takes more movement of the steering wheel to make the wheels initially move?
And this link maybe of some use
http://www.omegaowners.com/forum/YaBB.pl?num=1283124735
skinwiz
  • northwest
« Reply #5 on: 06 February 2011, 22:35:12 »
i had exactly the same problem with my motor just before the bad weather last year , i always felt like the car had a rough idea where i wanted it to be but was never quite sure , a friend tracked the car up for me and then we took it out for a quick spin , got back the tracking was waaaaay out . The culprit , wishbones , and it had passed an MOT not long before . I believe the bushes are quite hard to inspect visually , i could tell the difference straight away when the new ones were fitted .
« Last Edit: 06 February 2011, 22:35:38 by skinwiz »
please dont call me names , it just turns turns me on and i need BOTH hands to type .
unlucky mark mv6
  • tipton,west mids
« Reply #6 on: 06 February 2011, 22:41:24 »
I am also finding it very difficult to keep mine in a straight line,so i think its time i got the powerflex bushes fitted, ::)
« Last Edit: 06 February 2011, 22:42:08 by mlw »
the_omega_man
« Reply #7 on: 06 February 2011, 22:49:07 »
cheers for all the help guys! think il get wishbones replaced and get a full geometry check/adjust. also ive been told on another forum about adjusting steering box?
« Reply #8 on: 06 February 2011, 22:54:27 »
http://www.omegaowners.com/forum/YaBB.pl?num=1268642813 :y
Steve Pearce
  • Stonnall, Staffs
« Reply #9 on: 07 February 2011, 11:40:35 »
Its perhaps worth mentioning, i was having a similar sounding issue, car wandering around, seemingly affected by cambering on the road and things. Gave it an MOT as ive only just got it and it failed on the front bush, though when we've inspected it properly the rear one was quite bad also. Currently the whole wishbone is being replaced as its only a few quid more.
Il let you know if that cures it!
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #10 on: 07 February 2011, 11:44:29 »
if the car feels strange when changing gear I would be looking at rear do-nut bushes as they will make the rear of the car move around
other rides
the_omega_man
« Reply #11 on: 07 February 2011, 22:44:23 »
*update* havnt had chance to give the car a good looking over as i work alot of hours, but i noticed on the way home im getting quite bad wheel wobble at around 50mph and the car seems to veer from one side to the other on straight roads. gets really bad in the wind!
Hannah Judes Dad
    • the misses round the bend
« Reply #12 on: 07 February 2011, 23:27:09 »
Steering idlers ?
(not going in a straight line)
Wheel weights come off? Wheel bearing?
(wheel wobble at 50 mph)
Just an idea
the_omega_man
« Reply #13 on: 08 February 2011, 13:09:57 »
right ive had time to get under the car and give everything a shake, drivers side wheel was tight no movement or play at all,wishbones seem fine too.
But the passengers side had alot of play from the part in the picture. would this cause all the wondering and vagueness in the steering? also is it cheap enough to replace?
[/img]
[/img]
Hannah Judes Dad
« Reply #14 on: 08 February 2011, 13:46:23 »
The part you are pointing to does look like a steering idler to me.They can be replaced by yourself,you might want a second pair of helping hands.The maintenance guide below shows you how to do it.If you can afford genuine Vx parts then get them as the pattern parts aren't much cheaper to buy but in the long run will need replacing quicker.
Here's the link how to do it :-
http://www.omegaowners.com/forum/YaBB.pl?num=1268602974
