Author Topic: Orange light comes on in my car and then goes off  (Read 9018 times)
Wayne
« on: 18 December 2010, 23:52:15 »
guys, cant describe the actual light that comes on in my car, is there an image on here and i can show you which one it is?
the light in question comes on after ive been driving for about 10 minutes, then goes off after about 1 or 2 minutes, then other times it doesnt come on at all, should i be worried?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Orange light comes on in my car and then goes off
« Reply #1 on: 18 December 2010, 23:57:16 »
Go and see TB, he'll plug in his magic box and tell you what's up.
TuBy's new whipping boy.
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #3 on: 19 December 2010, 10:54:05 »
Picture of an engine? If so, paperclip it.
I think all other orange ones have letters written on it?
« Reply #4 on: 19 December 2010, 10:55:02 »
That won't be possible for a couple of days - nobody in a 2WD car will make it up or down 'Brackley Mountain'
« Reply #5 on: 19 December 2010, 10:57:26 »
/\ TB, with tech 2 just up the road in Brackley. /\
But worth a paper clip test first.
Wayne
« Reply #6 on: 20 December 2010, 15:49:19 »
The orange symbol looks like a sort of tap :o
i think its next to the TC symbol on the right
it hasn't come on for 2 days and is very intermittent
« Reply #7 on: 20 December 2010, 16:02:18 »
The manual is for a later car, but most of the warning lamps are the same.
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf  :y
« Last Edit: 20 December 2010, 16:04:25 by Andy_B »
Wayne
« Reply #8 on: 20 December 2010, 16:14:19 »
OH BUGGER!
My fault is the middle symptom
should i not drive it?
it only had a new exhaust and cats about 2 years ago
i hardly use the bloody thing
Exhaust emission
Control indicator lights up when ignition is
switched on. Goes out  shortly after engine
starts.
If it lights up when the engine is running:
Fault in the emission control system. The
permissible emission limits may be exceeded.
Consult  a Vauxhal l Dealership immediately.
If  it flashes when the engine is running:
Fault  which may damage  the catalytic
converter – see page 150.
Consult a Vauxhall
Boditza
  • Craiova, Romania
« Reply #9 on: 20 December 2010, 17:34:19 »
OH BUGGER!
Exhaust emission
starts.
Consult a Vauxhall
no offense but why don't you listen to what they sayd?? read the codes and you wil get help. Again folow this link and read your codes, post here and the guys will tell you what to do because you can't go wrong on this forum
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Reply #10 on: 20 December 2010, 17:37:02 »
OH BUGGER!
Exhaust emission Control indicator lights up when ignition is
starts.
Consult a Vauxhall
Your car hasn`t got an "emissions" warning light
« Reply #11 on: 20 December 2010, 18:21:30 »
yet again you are running around like a head less chicken!
We have gone from, "light looks like a tap" to "My fault is the middle symptom"  ::)
Have you actually done a paperclip test?
« Last Edit: 20 December 2010, 18:21:57 by tunnie »
« Reply #12 on: 20 December 2010, 18:25:54 »
yet again you are running around like a head less chicken!.....
Oh yes! I'd forgotten about that. What was that 'fault'?  ;) ;) ;)
« Reply #13 on: 20 December 2010, 19:01:07 »
Wayne - you car does not have an emmissions light - on the 2.5 (and 3.0), that symbol is actually the Engine Management light.
This means the engine ECU has detected a fault.
Look in the Maintenence Guides Index for Paperclip test, and post up results :y
And at the moment, don't panic, just post up the results of that test :) - we'll let you know when its time to panic ;D
amba
  • Medway towns
    • German V6
« Reply #14 on: 20 December 2010, 23:34:17 »
Must be contagious as I have had eml come on and off for most of the day.
I did a paperclip read and it came up as "89" which I am assuming is the n/s lambda sensor possible playing up...may be a loose wire or the sensor is on its way out.
I do have a spare lamba so when can get under car in dry will get them swopped over as another 4-6 inches of snow has fallen today.
Strange thing is car is running fine with no hesitation or uneven tick over so not much to worry about ...I hope.
Do the clip test wayne...you may find a similar problem as mine.
