Author Topic: Wishbones  (Read 1706 times)
Xenon
Wishbones
« on: 12 February 2011, 18:45:37 »
Can someone give a link to recomended wishbones please? :y
Hannah Judes Dad
    • the misses round the bend
Re: Wishbones
« Reply #2 on: 12 February 2011, 23:39:32 »
The general recommendation is to fit Lemforder ones... Not sure about the quality of the ones in the link but I've had 2 sets of cheap ones from ebay (for not a lot more than that for the pair) and been reasonably happy... But then I fit them myself ;)
Re: Wishbones
« Reply #3 on: 13 February 2011, 02:44:55 »
There have been several bad reports on here re Delphi wishbone bushes.
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Re: Wishbones
« Reply #4 on: 13 February 2011, 08:29:11 »
 The link says the wishbones are guaranteed.
I wander how good the 12 months guarantee is and what it covers?
best wishes
Simon.
Xenon
Re: Wishbones
« Reply #5 on: 13 February 2011, 11:57:34 »
Thanks for the replies. These are the bushes I need http://cgi.ebay.co.uk/VAUXHALL-OMEGA-WISHBONE-BUSH-REAR-1994-/220377350990?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item334f83834e as I have powerflex fitted and the ball joints are ok. What type of place could press them in for me?
Re: Wishbones
« Reply #6 on: 13 February 2011, 12:39:12 »
Anywhere with a press, some garages have them, or engineer shops. A small press would be ok for the rear, about 1.5 tons is enough ime. Although the fronts need about 8 or 9 tons of pressure, possibly more.
The other important part needed are drifts. Something just the right diameter to support the complete circumference of the rear of the wishbone to allow the bush to pass through as it's pressed out, otherwise the wishbone could bend. Although i found it easier to cut the bush out first by drilling through then hacksawing out prior to pressing as it's one less drift/process needed. But more than one drill bit will be needed for sure. ::)
Once removed pollish the internal area to remove any burs or corrosion, do not lubricate. Pressing the new bush in is easier than removal ime. Just make sure it's kept square or it will collapse.
Hth
Re: Wishbones
« Reply #7 on: 13 February 2011, 12:45:50 »
Guarantee won't cover removal and re fitting. It may be Delphi have improved their product as those bushes look differant to the Delphi ones I have seen.
I still say lemforder is the most reliable way to go tbh, 2year warranty, but 120 a pair from allgerman parts.
There are numerous £50 a pair sets around, and some have had good results, but can't say what make they have. Therefore a gamble on longevity.
Xenon
Re: Wishbones
« Reply #8 on: 13 February 2011, 12:46:20 »
Hth
Thanks, do you think the ones in my link are ok? They seem cheep.
Re: Wishbones
« Reply #9 on: 13 February 2011, 12:46:20 »
What make Is that bush? Vx don't make bushes.
« Last Edit: 13 February 2011, 12:48:17 by chrisgixer »
Xenon
Re: Wishbones
« Reply #10 on: 13 February 2011, 12:46:51 »
I'm not sure.
    • 530D M Sport, 330i Coupe
Re: Wishbones
« Reply #11 on: 13 February 2011, 12:49:42 »
My take on it is to fit the Lemforder wishbones then after a couple of years pop in some front poly bushes. At the age / mileage of these vehicles I think it's important to remember that the rear bush and bottom ball joint could be near the end of their useful life as well.
Re: Wishbones
« Reply #12 on: 13 February 2011, 12:51:46 »
Hmmm, I wouldn't fit those personally. Far too cheap. Could be any old shite.
Suggest a call to Jason at allgermanparts. He can supply the genuine lemforder items. More money, but there's nothing better afaik.
Xenon
Re: Wishbones
« Reply #13 on: 13 February 2011, 12:54:33 »
I already have powerflex bushes fitted. :y
