Author Topic: water in car  (Read 3769 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
water in car
« on: 10 February 2011, 21:26:53 »
Having dried out the car after the last influx when I suspected the scuttle drain which was completely clear when I inspected it. I now have water again  in the passenger side. I suspect the windscreen or a perforated bulkhead maybe in the drain area.  Any ideas or suggestions.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: water in car
« Reply #1 on: 10 February 2011, 21:34:52 »
Might be worth removing the kick board and you laying in there with a torch while somebody else fires a hose at the windscreen area. Might give you a fighting chance of seeing if it is the scuttle or screen rubber.  :-/
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: water in car
« Reply #2 on: 10 February 2011, 22:00:47 »
Is the kick board the padded area infront of the feet is it easy to get out?
Re: water in car
« Reply #3 on: 10 February 2011, 22:32:59 »
Easy. :y
3 large finger tight twist clips (have a slot for a modest flat bladed screwdriver) and it will drop down, then a sharp tug to free it from the clips on the bulk head. :y
YZ250
Re: water in car
« Reply #4 on: 10 February 2011, 22:42:31 »
Under glove box above your feet. As already said, easy to remove with a flat blade screwdriver or even a small coin. Just turn them through 90 degrees.
If it's anything like mine, the Nokia handsfree kit falls in my face where I have stuffed it up there behind the board.  ;D ;D
Re: water in car
« Reply #5 on: 10 February 2011, 22:46:14 »
Be careful as you turn them ... they break very easily .. and if anyone has any lying around I still need a couple of replacements .. :)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: water in car
« Reply #6 on: 11 February 2011, 11:40:41 »
Thanks for your help when it stops raining I will have a go I must admit that I thought that I might take the glove box out to help examination
Re: water in car
« Reply #7 on: 11 February 2011, 11:42:39 »
Now I would have thought that WHILE it was raining was the best time to look !!!!!!!
 ;D ;D ;D ;D ;D ;D ;D ;D
Re: water in car
« Reply #8 on: 11 February 2011, 13:01:30 »
Got some more here Nige, will bring `em up with the door :y
Omega Man
  • Oxfordshire
Re: water in car
« Reply #9 on: 11 February 2011, 13:22:04 »
I had wet carpets when I first got my Elite, it turned out that the windscreen was only half glued in :-[ Only found that out by having the front windscreen replaced £450 later :( Carpets dry now :y
Re: water in car
« Reply #10 on: 11 February 2011, 13:24:50 »
You is a star .. we're going off for the weekend later today, back Sunday, but no plans for next weekend at all..... so from Thurs to Sun whenever ... let me know and what you think about meeting "half way"
YZ250
Re: water in car
« Reply #11 on: 11 February 2011, 15:09:40 »
Good idea. It opens up the 'viewing' area much more.  :y
Good luck.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: water in car
« Reply #12 on: 11 February 2011, 16:38:04 »
If my windscreen is leaking I assume that cannot be claimed for replacement on insurance,only if is broken?
omega2.2auto
  • stirling
Re: water in car
« Reply #13 on: 11 February 2011, 21:33:17 »
fire a stone at it lol,check the water is not coming from the door as well mate.job for me tomoz someone has been in at the passenger door and hasnt replaced the door foil,and the water is coming in its soaking the door pocket grrr.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: water in car
« Reply #14 on: 12 February 2011, 17:19:35 »
I gave the car the hose pipe treatment today tried it on the door shuts right across the windscreen but no water in the car. Is it possible in a heavy downpour that the scuttle can overflow even when the  drain is clear I watched the outlet from the drain today and it appeared to flow OK.
