Author Topic: No heating inside car but temp guage normal  (Read 1400 times)
jiaomega
« on: 08 February 2011, 11:35:09 »
I am not getting any heat inside the vehicle although the temperature guage is normal. When I increase the temperature on the climate control the fan increases but still no hot air. Can anyone please advise what it is likely to be or any checks I can do to find out the likely cause. It is a 2.2 Petrol CDX Yr 2000
matt76
Re: No heating inside car but temp guage normal
« Reply #1 on: 08 February 2011, 11:49:45 »
Hi
My 2.2 cdx 2003 is doing the same the advice i have been given is airlock and to flush out the heater matrix
I_want_an_Omega
« Reply #2 on: 08 February 2011, 17:52:34 »
Probably the HBV - but could also be a blocked heater matrix.
If you do flush the matrix then do it both ways - you will be amazed the quantity of cr_p that comes out
omega2.2auto
  • stirling
« Reply #3 on: 08 February 2011, 20:48:30 »
mine done the same before xmas,while we had the bad weather.new thermostat done the trick,cooking now.
jiaomega
« Reply #4 on: 14 February 2011, 08:23:30 »
How easy is it to flush the heater matrix? does it have to be removed to do this or can it be done in situ? Thanks for any advice.
If you do flush the matrix then do it both ways - you will be amazed the quantity of cr_p that comes out[/quote]
jiaomega
« Reply #6 on: 14 February 2011, 10:38:11 »
Thank you, will try it tomorrow and hopefully it will work.
Page created in 0.027 seconds with 16 queries.
