Author Topic: Oil in plenum..  (Read 1406 times)
Oil in plenum..
« on: 13 February 2011, 19:18:44 »
Hi All,
Treated my mig to new spark plugs today as she's been missing quite badly at low revs. Seems OK at higher revs tho..
Anyway, when I removed the plenum the inside of the chamber seemed quite oily.  The breathers were clear, but there was a fair bit of mayo in the large twin pipe.
Dosn't seem right to me  :-/ Anyone know the cause?
Thanks :y :y
Bent valve
Re: Oil in plenum..
« Reply #1 on: 13 February 2011, 19:33:33 »
I dont know why you removed the plenum to change the plugs, but it is quite normal to have an oily residue on the inside of the plenum. By 'large twin pipe' do you mean the one from the breather box to the plenum? if so it is normal for that to get blocked over time especialy if used for short runs.
Re: Oil in plenum..
« Reply #2 on: 13 February 2011, 20:15:56 »
Might have an airleak somewhere causing the missing, so took it off so I could clean it up, check the breathers and put it back abit more carefully than I did last time  ::).  Also changed the HBV :y
Yes the large breather pipe that splits in two :y
« Last Edit: 13 February 2011, 20:19:02 by TiggerHayes »
Re: Oil in plenum..
« Reply #3 on: 14 February 2011, 11:08:22 »
Oil is from the breather system, that's how it works. The Mayo is a sign they could be blocked, obviously give the breathers a clean out wit carb cleaner and give tem a blow through to double check they are clear, this checks the breather box on crank case is clear also.
