Author Topic: alarm actuating in wet  (Read 2627 times)
delwillmer
« on: 13 February 2011, 22:34:24 »
Hi, I am new to this site and have a problem with my S reg 2.5 V6. Now and again the alarm will trigger but only when it is raining hard. This can happen whilst driving, embarassing, or when stationary, equally embarassing if in traffic. Everything still works when this happens. Can I simply disconect the horn located on the drivers bulkhead?
Del
« Last Edit: 13 February 2011, 22:34:59 by delwillmer »
RobG
    • 16 plate Mokka. Vivaro
Re: alarm actuating in wet
« Reply #1 on: 13 February 2011, 22:41:37 »
Yep, disconnect & remove the powersounder
delwillmer
« Reply #2 on: 13 February 2011, 23:05:41 »
Thank you. I have a haynes that says there is a powersounder under the wheelarch of the f/n/s wheel. what is this?
Del
  • Online Online
« Reply #3 on: 13 February 2011, 23:10:03 »
Del
Wrong  ;D
Power sounder is, as you say, under the driver's side of the scuttle.  :y :y
omegabsw
  • Essex
« Reply #4 on: 13 February 2011, 23:14:38 »
Del
Wrong  ;D
Where most vauxhall power sounders are, BUT......
I started to strip my V6 CDX today and there is some sort of power sounder in the front N/S wing
delwillmer
« Reply #5 on: 13 February 2011, 23:15:18 »
Thanks a lot Andy. Looks like a job for tomorrow
Del
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #6 on: 13 February 2011, 23:17:36 »
ummm n/s front wing isnt that just the normal horn   :-? :-?
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #7 on: 13 February 2011, 23:38:51 »
 Disconnecting the power sounder alone will not stop the alarm going off as the sounder and horn work in tandem. That said it's well worth while removing the power sounder all together to prevent your Omega bursting into flames :o
As to the alarm going off whilst driving it sounds like a short somewhere because it should not activate when the ignition is turned on.
omegabsw
  • Essex
« Reply #8 on: 13 February 2011, 23:40:45 »
I thought they did, so the one under the bonnet is the horn right? and the one under the wing is the alarm sounder? the one that beeps when the battery is low?
Tony H
  • liverpool
« Reply #9 on: 13 February 2011, 23:48:10 »
The power sounder is under the scuttle panel behind the offside strut mounting. If yours has started to emit a number of beeps thats a sign that the internal batteries are on there last legs and it is well recommended to remove the whole sounder(not just disconnect it) to prevent the risk of fire. The job whole takes about half an hour.
omegabsw
  • Essex
« Reply #10 on: 13 February 2011, 23:50:15 »
Its cool, im breaking the car.
So whats the one under the wing?
  • Online Online
« Reply #11 on: 13 February 2011, 23:50:30 »
No. ;) The power sounder is under the scuttle along side another horn which is also for the alarm. The car horn is a pair of horns under the nearside of the front bumper/wing. :y
fiend61
  • york
  • each to their own
« Reply #12 on: 13 February 2011, 23:52:37 »
  hmmm didnt i say that  beep beep :D :D ;)
« Last Edit: 13 February 2011, 23:53:35 by fiend61 »
omegabsw
  • Essex
« Reply #13 on: 13 February 2011, 23:58:02 »
Yeah thats what I thought, but this dont look like the "Normal" vauxhall pair of horns. its more like a black box with vents on the top like a speaker
  • Online Online
« Reply #14 on: 13 February 2011, 23:58:10 »
Aye! Tha did!  :y :y :y
Page created in 0.028 seconds with 17 queries.
