Author Topic: hazards flash  (Read 1540 times)
malcolm1973
  • falkirk
hazards flash
« on: 14 February 2011, 13:03:38 »
 :(hi my omega cd v6, just recently changed from elite , its a 2000 x , i have to lock it manually at the moment needs new fob, but when i unlock the car and enter the hazards flash until i turn the ignition light s on and im bewildered to why it does this any ideas of how to cure this thanks malc :-/
Re: hazards flash
« Reply #1 on: 14 February 2011, 13:08:21 »
Alarm is activating but it appears your powersounder has been removed. As you say, either key in ignition to stop them or shut all doors then open rear O/s & press driver`s doorpin down to lock manually. Remember to have your keys in your hand when you do this.
Re: hazards flash
« Reply #2 on: 14 February 2011, 13:31:46 »
Not quite.
It sounds like the HORN has failed (they all do, they're rubbish), not POWERSOUNDER.
Alarm horn (seperate from car horn) in same place as powersounder
omegabsw
  • Essex
Re: hazards flash
« Reply #3 on: 14 February 2011, 16:22:29 »
Not quite.
So what is the black box under the N/S front wing?
Re: hazards flash
« Reply #4 on: 14 February 2011, 16:27:35 »
Not quite.
Photo???
omegabsw
  • Essex
Re: hazards flash
« Reply #5 on: 14 February 2011, 16:38:18 »
omegabsw
  • Essex
Re: hazards flash
« Reply #6 on: 14 February 2011, 16:39:14 »
Does your horn work normally?
Re: hazards flash
« Reply #7 on: 14 February 2011, 18:37:04 »
Not quite.
ECU fan ;D
omegabsw
  • Essex
Re: hazards flash
« Reply #8 on: 14 February 2011, 19:18:57 »
Not quite.
ECU fan ;D
Well im glad that I have provided some entertainment at least
Re: hazards flash
« Reply #9 on: 14 February 2011, 19:22:29 »
Not quite.
ECU fan ;D
I'd no idea that lived there, but i was correct in it being a fan.  ;) ;) ;) (see other post with these pictures  ;))
