Author Topic: handbrake shoes  (Read 1413 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
handbrake shoes
« on: 14 February 2011, 19:12:38 »
hi all
are these any good for mfl 2.5 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310293481182&ssPageName=STRK:MEWAX:IT
or can anyone recommend what i should be looking for ?
thanks
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: handbrake shoes
« Reply #1 on: 14 February 2011, 19:14:21 »
I could have sworn all handbrake shoes are the same anyway..
Re: handbrake shoes
« Reply #2 on: 14 February 2011, 19:15:10 »
Any motor factors for handbrake shoes, same across the range :y
« Last Edit: 14 February 2011, 19:15:48 by RobG »
V6 CDX-er
  • Sheffield
Re: handbrake shoes
« Reply #3 on: 14 February 2011, 19:15:22 »
I'd reccomend for someone else to do the job, horrible things those handbrake shoes are.
Are you sure it is the shoes that are knackered, and not just adjustment that is needed?
fiend61
  • york
  • each to their own
Re: handbrake shoes
« Reply #4 on: 14 February 2011, 19:21:48 »
not sure but got MOT tomorrow so was pricing up just incase  ;)
adjustment is the star key through hole in disc  :question please advise if wrong  :y
thanks
Re: handbrake shoes
« Reply #5 on: 14 February 2011, 19:24:48 »
thanks
Yep......+ http://www.omegaowners.com/forum/YaBB.pl?num=1152564750
V6 CDX-er
  • Sheffield
Re: handbrake shoes
« Reply #6 on: 14 February 2011, 19:26:36 »
thanks
Both the 'star' type adjuster through the hole in the discs and the compensator bar under the car in about the middle.
My handbrake was awfull, resulting in me fannying about changing the shoes. I reckon just changing the disc and adjusting would have solved the problem a lot easier.
fiend61
  • york
  • each to their own
Re: handbrake shoes
« Reply #7 on: 14 February 2011, 19:26:43 »
cheers rob  :y
fiend61
  • york
  • each to their own
Re: handbrake shoes
« Reply #8 on: 14 February 2011, 19:30:57 »
cheers v6  :y
things you learn, when i first got car i hadnt heard of oof and had handbrake adjusted at garage, after much sucking of teeth and being told that heat shields and exhaust had to come off to be able to do it i parted with£160    lesson the hard way i guess  :'(
Xenon
Re: handbrake shoes
« Reply #9 on: 14 February 2011, 19:41:41 »
cheers v6  :y
Oh dear :(
