Author Topic: Front wheel bearing woe  (Read 1498 times)
robg1984
  • immigham n.e.lincs
« on: 16 February 2011, 16:23:30 »
 Ive changed the bearing on on wheel twice in the same amount of months admittedly they were second hand but its the same wheel bearing thats gone! Ive noticed that she pulls to that side so i have a tracking issue which will be getting sorted next week am just wondering if this could be causing the bearing to go any ideas to confirm or defunct this theory would be great  :)
Omegatoy
  • UK
Re: Front wheel bearing woe
« Reply #1 on: 16 February 2011, 18:03:22 »
they do get noisy and sloppy if you dont torque them up to the correct figure!!
robg1984
« Reply #2 on: 16 February 2011, 20:55:23 »
it was torqued up to 110 nm which i think is about right and there was no play whatso ever a few days ago nows theres play at 12 and 6 and it looks like another bearing is needed :'(
« Reply #3 on: 16 February 2011, 21:03:33 »
110Nm is NOWHERE near enough....its closer to 300Nm (cant remember the exact figure at the moment)
« Reply #4 on: 16 February 2011, 21:10:11 »
320Nm :y. 32mm socket....long breaker bar :)
Omegatoy
  • UK
« Reply #5 on: 16 February 2011, 21:14:27 »
as said you failed!! lol you need a large torque wrench otherwise the next bearing will fail as quickly as this last one!!
    • 530D M Sport, 330i Coupe
« Reply #6 on: 16 February 2011, 21:18:47 »
Yep, 320Nm, remember from doing mine. 110Nm is the wheel bolt torque.
robg1984
« Reply #7 on: 16 February 2011, 22:04:45 »
Thats where i went wrong i mustve read that instead off the wheel bearing one :'( lesson learnt  :) cheers guys :y
« Last Edit: 16 February 2011, 22:05:16 by robg7 »
« Reply #8 on: 16 February 2011, 23:32:29 »
Ask on here first, then do the job. :y
Page created in 0.048 seconds with 16 queries.
