Author Topic: coolant leak rear right of plenum-cam cover gasket  (Read 1653 times)
doug4293
  • greenock, scotland
« on: 09 February 2011, 23:36:38 »
just doen the rocker cover cam covers tonight,they needed sone as oil was getting into spark plugs and dripping onto exhaust, now when i noticed they needed done, i initially thought the spray of misty stuff then the puff of smoke/steam from the reat right of the plenum was oil from the cam covers, hence changed them, on completion let the car heat up, no drips of oil, but when revved hardish to over 4000, the same from rear right of plenum (near side) light spray, after doing it a few times i can see its definatly coolant, but cant see exactly where it could be coming from, also once the car was moved there was a puddle of coolant on the floor, has anyone had this before, it looks like its a strip down of the plenum again and check the hoses and the thermostat housing, but if any one can shed any light might point me in the right direction.
Signature deleted as it's too big.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: coolant leak rear right of plenum-cam cover gasket
« Reply #1 on: 09 February 2011, 23:41:27 »
From what you have said it could be either the HBV or one of the pipes off the coolant bridge... the thermostat is at the front of the enginbe so cant see it being that being honest mate :y
doug4293
« Reply #2 on: 09 February 2011, 23:46:32 »
ahh, right, anyone got a picture of the hbv so i can see what it looks like, also whats the blue plug going into the centre of the rear of the engine you can see when plenums off, as i thought it was the thermostat.
« Reply #3 on: 09 February 2011, 23:51:01 »
HBV is under the bottom of the drivers side of the windscreen. Looks a bit like a black starship enterprise. About the size of a fist.
Cant think what the blue plug is from memory tbh. :-/
doug4293
« Reply #4 on: 09 February 2011, 23:51:07 »
also forgot to mention heaters work okay cold and hot, although have noticed when just ticking over the are hot but if reved to 1500rpm, ish, the get slightly hotter,although think this is normal
« Reply #5 on: 09 February 2011, 23:57:47 »
Start off by checking the HBV, and take it from there.  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
doug4293
« Reply #6 on: 10 February 2011, 00:19:21 »
great, that lets me get into that area (removing the wipers and plastic scuttle) without taking the plenum off, so i can run the car and look down here to try and see exactly where the leaks from.
« Last Edit: 10 February 2011, 00:45:13 by doug4293 »
« Reply #7 on: 10 February 2011, 00:23:34 »
Yep, thats the way to do it. :y
« Reply #8 on: 10 February 2011, 09:30:22 »
Blue plug that goes into what looks like a water gallery? IIRC from the other weekend, that's the temperature sensor plug :)
doug4293
« Reply #9 on: 17 February 2011, 20:22:19 »
found it, its the pipe on the hbv that goes to the engine inbetween the two heads, have replaced it with another piece of pipe i have handy, although its not the same shape, will this be oky, or is the origonal pipe shaped the way it is (a square circular shape) to dampen the flow of the coolant ?
