Author Topic: Re:Omega Diesel won't start  (Read 4498 times)
350sb
  • London
    • X reg 2.5 TD GLS
« on: 13 February 2011, 14:52:22 »
Hi Guys,
I desparately need help with my tractor.
I went to turn the key in the ignition last night and the engine wouldn't turn, like there was no battery connected.I  checked the battery connections and they were all fine. I disconnected the battery and reconnected it again, but this time the dash lights that go off once you start the car stayed on without the key in the ignition. There is also an issue with one of the relays clicking on and off.
What is the cause here?
Thanks
Shaun :(
Re: Re:Omega Diesel won't start
« Reply #1 on: 13 February 2011, 14:54:23 »
Posting twice doesn't get get your car diagnosed twice as fast.  ;)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 13 February 2011, 14:56:42 »
Try the jump lead test.
Click:  http://www.omegaowners.com/forum/YaBB.pl?num=1297607904  to see my original reply mate.
« Last Edit: 13 February 2011, 14:58:09 by Reliance505 »
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #3 on: 13 February 2011, 15:10:57 »
Sorry for posting twice guys.
I tried clicking on the thread below but the is no link.
Where do I start with the jump lead test?
Thanks
Shaun
Boditza
  • Craiova, Romania
« Reply #4 on: 13 February 2011, 16:32:25 »
change the battery with a friends one or try some jump leads from another car
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #5 on: 13 February 2011, 18:26:57 »
Hi,
Swapped the battery and still the same problem, i.e. the dash lights that are meant to go off are still on without the key. Also,there are no clicks when turning the key.
Shaun
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #6 on: 13 February 2011, 18:34:07 »
Have you done any work on the car at all before this problem started.
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #7 on: 13 February 2011, 18:54:31 »
I only fitted a "Hot start fix" from Tawpark 4x4 back in August last year. Apart from that, I've been removing the battery to put on charge since the cold weather started. :(
hoofing it
« Reply #8 on: 13 February 2011, 19:26:34 »
If the dash lights are still on its an earth fault.
Get a set of jump leads connect to the negative on battery and the other end to the engine and also using the other jump lead connect from the negative to the ecu which sits under the cover next to the battery :y
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #9 on: 13 February 2011, 22:55:18 »
Thanks,I will try the jump leads tomorrow.
Seth
« Reply #10 on: 14 February 2011, 00:50:47 »
Thanks
Shaun
Securely clamp one end of a jump lead to the NEGATIVE (-) battery terminal, then securely clamp the other end to a suitable point on the engine itself (such as a manifold nut/stud).
See what happens.
Your symptoms make me strongly suspect an earthing problem here ;)
« Last Edit: 14 February 2011, 00:51:40 by Reliance505 »
x25dt
  • Portugal
« Reply #11 on: 14 February 2011, 15:19:01 »
Hi do you recommend the "hot start fixing"?
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #12 on: 14 February 2011, 19:11:12 »
I tried the jump lead test and the lights don't go off but remain on. There is a relay that keeps clicking when connecting/disconnecting the battery as I disconnect the battery when locking the car.
Is it possible that the ignition could be stuck in a certain position? It happened when i turned the ignition key but felt no click.
The hotstart fix has worked fine until my current appeared but I was advised by Jeremy Fern that the pump will need to be reconditioned at some stage.It will lead to a loss in power and I wish there was a rebuild kit out there for it.
Omegatoy
  • UK
« Reply #13 on: 14 February 2011, 20:01:39 »
oooh, ok think i know what has happened here, this is an old fault that has affected a few omega diesels,
before i go any further the power sounder has been thrown ?
just to eliminate that!!!
ok looking at the battery from the top look down till you see 2 or 3 large connectors just above the abs unit, if you get your hand down there and follow the top most brake line you will probably find that it has been rubbing on the cables,eventually the insulation rubs through and the wires connect through the brake pipe, this causes a dead short through the ignition, which is probably why your ignition is still on? if you remove the battery its easier to see the cable connectors are clipped in and are easily unclipped to check the wires im on about!!
lol just read it back and it does sound a little awkward but it is understandable to me!! there was a post i did on this proabably 3  years ago now but i cant find it !!
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #14 on: 16 February 2011, 19:34:00 »
Omegatoy,
It's either I can't find these wires or I'm lost.
When you say looking from the battery down, which connectors am I to look for?
How do I paste pictures in this message?
I've disconnected what I think is the powersounder or siren,but the lights still stayed on and forgot to mention previously the fuel gauge was also on.
Please help me, as I desparately need this car on the road asap.
