Author Topic: Faulty Elite heated seat?  (Read 1148 times)
Malcolm_D
  • York
  • It shines!
« on: 17 February 2011, 11:47:01 »
Drivers seat worked well (probably too well - very hot!) when I first got the car, now it doesn't appear to work at all. Have checked the fuse, also the passenger seat works, light on at switch. Anything else to check before I assume the element has given up? How easy is it to replace the heating element in a leather seat?  ;)
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
Re: Faulty Elite heated seat?
« Reply #1 on: 17 February 2011, 11:58:56 »
Common one this.. mine is exectly the same - and its easier to change a seat than the element in it - or live without it as I do (passengers are sorted!)
Carfix
  • Malmesbury, Wiltshire
    • 1997 & 1998 Omega Elites
« Reply #2 on: 17 February 2011, 14:37:29 »
Mine failed too. Had this on my pre-facelft CDX. The seat base got very hot for a minute then nothing. As the seats were cloth I was able to strip down the base and replace the heater pad. The heater pad had an obvious burn mark were the element had shorted out
However, I think the construction of the leather seats is different with the heater pad being sewn into the leather. Much more difficult?
Malcolm_D
  • York
  • It shines!
« Reply #3 on: 17 February 2011, 21:25:18 »
Why am I not suprised that it is going to be a difficult job? Story of my life :(
The concern I have with changing the seat is that it is in good nick and will a replacement be a good colour match?
Most likely will live without it.
« Reply #4 on: 17 February 2011, 22:03:43 »
Just put a heater element in under the seat base. The heat will take longer to get to your backside ...... but better than nowt.  ;)
