Author Topic: Help!!!!!!!!! Please  (Read 3316 times)
rob69
  • Lincoln
« on: 19 February 2011, 19:44:26 »
I drove my car home from work last (2000 2.5 elite 80k auto ) as usual she drove perfect no problems nothing suspicious happened.
But this morning i went to go to work and got in car and turned her over and she just spins and doesnt fire at all.
 i have checked the obvious i.e: fuel and the batterey has plenty of punch but it just wont fire ?????????
p.s i also checked that the chip thingy is still in the key fob so im lost any help please ?????????????? i need to get it running asap for work.
A friend has suggested it might be the crank sensor and has offered to come over in the mornin and remove his sensor  and fit it to mine to see if thats the problem anymore help guys from your knowledgable heads please. :-/
Re: Help!!!!!!!!! Please
« Reply #1 on: 19 February 2011, 19:46:56 »
Do the paperclip trick and post up any codes .. if you get a 19 it is almost certainly the crank sensor.
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
HTH
rob69
  • Lincoln
« Reply #2 on: 19 February 2011, 21:57:04 »
thanks gonna try that at first light :) will post the results
rob69
  • Lincoln
« Reply #3 on: 19 February 2011, 22:00:35 »
forgot to ask, if it is crank sensor where is it located and how hard a job is it to change and where is best place to source one at what price??
« Reply #4 on: 19 February 2011, 22:09:38 »
It lives next to the oil filter, is around £50 & you need to buy OE. Pattern don't last.  :y
Omega      Part Number      Retail Price      Normal Trade      Trade Club
Crankshaft sensors
2.0 16v to 14194716      90458251      £60.50      £54.46      £47.10
U25TD/X25TD      90487810      £98.50      £88.65      £76.94
2.5 (early models)      90492006      £83.50      £75.15      £65.12
2.5 (later models)      90492061      £61.50      £55.36      £47.88
2.0 8v      90493864      £60.50      £54.46      £47.10
2.0DTi/2.2DTi      90540188      £37.75      £33.98      £29.40
2.6/3.0/3.2      90540743      £55.00      £49.56      £42.63
2.0 16v from 14194717/31000001      9174621      £36.60      £33.00      £28.47
« Last Edit: 19 February 2011, 22:14:30 by Andy_B »
rob69
  • Lincoln
« Reply #5 on: 19 February 2011, 22:16:05 »
thanks andy is it a a bitch to do or nice easy job lol?
rob69
  • Lincoln
« Reply #6 on: 19 February 2011, 22:19:27 »
i am continually amazed by the fast and concise response from you guys thanks again i can only imagine you have brains the size of beach balls to hold all that info lol
« Reply #7 on: 19 February 2011, 22:21:46 »
less than 30 minutes ... and only one torx-bit (T8) needed  :)
have a read here ...
http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
« Last Edit: 19 February 2011, 22:22:38 by entwood »
« Reply #8 on: 19 February 2011, 22:22:27 »
 :-[ :-[ :-[ Someone else has done both of mine.  ::) ::) ::)
V6 CDX-er
  • Sheffield
« Reply #9 on: 20 February 2011, 00:57:15 »
I've just had to remove mine to give it a good clean, (wrong oil filter fitted, which then exploded sending oil everywhere).
It's really easy to get to and to undo the E8 bolt, (I think an 8mm or 6mm should also fit?), but do be carefull getting it out. If it feels stuck, which it likely will do, gently give it a prise with a flat bladed screwdriver and try gently giving it a little wiggle. Eventually after a good 5-10 minutes it will come out.
I cant stress enough that you need to be gentle with it.
I cant comment on the wiring side of it, as all I did with mine was remove it to clean all the oil off it.
rob69
  • Lincoln
« Reply #10 on: 20 February 2011, 09:02:30 »
ok i did the paper clip test this morning and all im getting ids the 12 =start then 135=low voltage and the 31=no rpm.
The batterey was fine before and is probly a lil low now  as i have tried to turn it over several times i already knew that lol so im still lost??????????????
rob69
  • Lincoln
« Reply #11 on: 20 February 2011, 10:12:40 »
where would an oofer go next or what would he check lol ????????
rob69
  • Lincoln
« Reply #12 on: 20 February 2011, 10:44:09 »
ok guys been out there again pulled a few plug leads off and im not gettin any spark from any of the leads so does that mean its the coil pack ???????????
  • Auckland
    • Mazda MPV
« Reply #13 on: 20 February 2011, 10:50:58 »
Code 31, no RPM so either
- the engine isn't turning
or
- the crank sensor is FUBAR and can't sense the engine is turning
No crank sensor = no spark
When my crank sensor failed (on a 1994 2.5 V6) I didn't get a code 19.
rob69
  • Lincoln
« Reply #14 on: 20 February 2011, 11:08:53 »
thanks mate but dunno if that complicates it or makes it easier lol is there a way of findin out what it is before i start taking stuff apart?????
