Author Topic: thumping sound when braking or hitting bumps !?  (Read 809 times)
questor
« on: 21 February 2011, 19:33:17 »
Hi i have a 1999 omega with 54k on the clock, i get a thumping (dull thud) from the front of the car when i brake hard or hit a bump in the road, has been there for about 6 months now and it is due MOT soon, suspect it's a suspension thing but no idea where to start looking...
Any help will be welcome
Ta  Chris
Re: thumping sound when braking or hitting bumps !?
« Reply #1 on: 21 February 2011, 19:36:45 »
I would look at the drop links first, if not them then the rest of the suspension components - wishbones, springs dampers etc. :y
questor
« Reply #2 on: 21 February 2011, 19:58:57 »
ok thanks will do....
« Reply #3 on: 21 February 2011, 20:29:28 »
Personally I'd start with the front wishbone bushes ;) ;)
Bet you get a pull if you brake very hard too ::)
questor
« Reply #4 on: 21 February 2011, 21:55:15 »
ok ta, will check them out, does not pull tho...but i don't do much hard braking.... well i'll try tmw ... once  i've  checked there's nobody behind lol
ta
« Reply #5 on: 21 February 2011, 22:09:48 »
As Albs says - replace droplinks first - most likely the cause and cheap (~£7 ea) and dead easy to swap  :y
