Author Topic: Whining Gear box  (Read 2482 times)
Jezzer
  • Herts
Whining Gear box
« on: 22 February 2011, 11:16:49 »
Hi All
The Autobox on my 2.0 16v CDX (1999) is whining but only about 50mph.
It starts with a low whine about 35mph and gets worse till 50. Then goes quieter to 70-80 mph no noise at all?
Is not using any oil, (had a full change 8k ago) all functions on the box work perfectly, smooth changing, no clunking, Sport/Winter and kick-down all AOK?  :y
But has been getting gradually worse over the last 10k.
Done 5,000 with it like this including all round Ireland and Scotland and never let me down?
It is irritating but as long as it stays reliable I can live with it?
Any ideas  :o
mkirky
  • Cheshire
Re: Whining Gear box
« Reply #1 on: 22 February 2011, 11:19:32 »
Are you sure its the gearbox and not the prop shaft
Jezzer
  • Herts
« Reply #2 on: 22 February 2011, 11:22:16 »
Not sure?
Is there any way I can test it and find out?
Jezzer
  • Herts
« Reply #3 on: 22 February 2011, 11:24:09 »
Also, if it was the prop-shaft, can the joints be lubricated or will I have to replace them or the entire shaft?
mkirky
  • Cheshire
« Reply #4 on: 22 February 2011, 11:25:20 »
Will have a look in the workshop manual
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #5 on: 22 February 2011, 11:34:22 »
......or diff. I get a bit of a whine from my diff between speeds of 50 and 70 although not serious.
mkirky
  • Cheshire
« Reply #6 on: 22 February 2011, 11:36:36 »
Thats a good point have you check your diff oil
Jezzer
  • Herts
« Reply #7 on: 22 February 2011, 12:05:47 »
DIFF OIL
No I haven't - in for an MOT Thursday so will get the guys to check it?
The whining seems to be from the back of the box, some may be the front prop shaft bearing?
Sound doesn't seem to be as far back as the diff?
Any thoughts  :-?
mkirky
  • Cheshire
« Reply #8 on: 22 February 2011, 12:18:14 »
Propeller shaft centre bearing and check the centre bearing support bracket also there is a vibration damper at the front of the prop shaft and uj s
Jezzer
  • Herts
« Reply #9 on: 22 February 2011, 12:32:15 »
Brilliant help again!
Thanks mKirky - I'll get the guys at 'The Car Works' to check out the prop and diff and post findings on Friday!
Many Thanks
The Car Works, Berkhamsted Herts www.the-car-works.com
HIGHLY RECOMMENDED FOR OMEGA OWNERS!
mkirky
  • Cheshire
« Reply #10 on: 22 February 2011, 12:45:55 »
Hope it ends up a cheap fix :y
Jezzer
  • Herts
« Reply #11 on: 22 February 2011, 12:51:38 »
Me too mkirky, or goes on for at least another 10k so I can find a 2.2 DTI Facelift Auto - rare as rocking horse poo!
