Author Topic: Dis/Coil Pack  (Read 852 times)
MikeDon
Dis/Coil Pack
« on: 23 February 2011, 11:51:35 »
Hi guys,
Which coil/dis pack is the correct one for a 2001 3.0 elite?
Been on Eurocarparts and there are 5 different ones  :-/
Need to keep car on road so don't want to be taking stuff apart twice and had a look to see if I could see a part number.... which I now know was obviously a waste of time!
They (Eurocar) seem to distinguish between an estate and a saloon too, are there different coils on them?
Thanks, Mike
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Dis/Coil Pack
« Reply #1 on: 23 February 2011, 14:17:42 »
as a rule, i think the differance between the 2.5 / 3 ltr v6's  is the shape of the plug on the LT side  :y
you will find that the plug on the end of the MAF sensor ( pipe that comes from the airbox ) is the same shape as your coil pack  :y
some have square corners or some have ovel shaped conectors  :y
engine is a engine  ;)
no diffferance between saloon and estate  :y
« Last Edit: 23 February 2011, 14:19:00 by tigers_gonads »
MikeDon
Re: Dis/Coil Pack
« Reply #2 on: 23 February 2011, 15:56:24 »
thanks, that will save a bit of time then... will take a look at that when I get home....
Strange that eurocarparts list some for estate and others for saloon?!  ::)
