Author Topic: Fault code 96  (Read 1119 times)
robg1984
  • immigham n.e.lincs
Fault code 96
« on: 23 February 2011, 19:16:36 »
 Hi all changed the glows on my 2.5 td and was pretty sure id put everyhing back right but ive put the fault code reader on it tonight and code 96 which is egr valve out of range could this just be a case off ive pu the wrong pipe in the wrong place??
Re: Fault code 96
« Reply #1 on: 23 February 2011, 19:47:08 »
assuming vac pipes on, and valve is clean, I'd be inclined to ignore it to be honest.
hoofing it
Re: Fault code 96
« Reply #2 on: 23 February 2011, 20:08:45 »
And blank it off :y
robg1984
Re: Fault code 96
« Reply #3 on: 24 February 2011, 16:49:10 »
Will do  :y i just saw the code and thought what now  :( but glad its nothing tho worry about   :)
« Last Edit: 24 February 2011, 16:50:17 by robg7 »
