Author Topic: oil cooler  (Read 1106 times)
tango
  • brum
oil cooler
« on: 24 February 2011, 18:37:47 »
hi guys
quick question
sorry for being thick but does the oil cooler cool the engine or gear box oil
and if it cools the engine oil then would you see a drop in oil level if the cooler failed
thanks
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: oil cooler
« Reply #1 on: 24 February 2011, 18:39:52 »
Oil cooler, cools engine oil, if oil cooler has gone or going oil will be in your water system  :y
Re: oil cooler
« Reply #2 on: 24 February 2011, 19:09:20 »
it sits in the valley of the 'V' in full coolant flow, so good coolant maintenance is essential. If it starts to leak, then oil goes into the coolant system  :y
Re: oil cooler
« Reply #3 on: 24 February 2011, 19:11:29 »
hi guys
quick question
thanks
There are 2 oil coolers on auto models
One in the V of the engine as said - and one in the Radiator, for cooling the auto transmission fluid
I expect it's the engine cooler you're referring to, though.
Do you have a fault, or are just curious? :y
tango
  • brum
Re: oil cooler
« Reply #4 on: 24 February 2011, 19:21:11 »
thanks for the repliies
actually i have taken out the oil cooler from the v as i was loosing oil and was get like a sludge in the water
