Author Topic: v6 2.6 crankshaft sensor location  (Read 1725 times)
vomega51
  • east london
« on: 24 February 2011, 18:07:32 »
hi, can anyone tell me where the crankshaft sensor is located on a 51 plate 2.6 v6 and whether its a diy job or garage, thanks, kevin
Re: v6 2.6 crankshaft sensor location
« Reply #1 on: 24 February 2011, 18:09:14 »
DIY....next to oil filter. Guide in "maintenance"
« Reply #2 on: 24 February 2011, 18:09:20 »
DIY, Passenger side, next to the oil filter/canister  :y
« Reply #3 on: 24 February 2011, 18:09:45 »
nuts, 6 seconds too slow  ;D
vomega51
  • east london
« Reply #4 on: 24 February 2011, 19:32:33 »
CHEERS LADS, :y :y :y
« Reply #5 on: 24 February 2011, 19:42:43 »
Has yours failed :o :o
They NEVER fail ;)
vomega51
  • east london
« Reply #6 on: 24 February 2011, 19:55:18 »
the engine keeps cutting out whilst driving, other members suggested the crank sensor, done a pedal test today and came up with code 0155, can you shed any light please, thanks, kevin
« Reply #7 on: 24 February 2011, 20:10:04 »
Sorry, ignore me, its the drugs for the manflu.
Cranksensors frequently fail, of course. I thought you said cam sensor. As said, ignore me ;D
When it dies, does it just cut, and does it do it at cruising revs, or is it only at idle? Does it hunt before dying?
« Reply #8 on: 24 February 2011, 20:11:17 »
TB ... already a thread running on this ..
http://www.omegaowners.com/forum/YaBB.pl?num=1298320594
vomega51
  • east london
« Reply #9 on: 24 February 2011, 20:15:00 »
it seems to shudder and then cut out whilst cruising and at idle
  • Auckland
    • Mazda MPV
« Reply #10 on: 24 February 2011, 21:02:19 »
I am curious about the 0155 code.
The O2/Oxygen/Lambda sensors have to be kept hot to measure the amount of oxgyen in the exhaust gases. When the engine is cold the fueling runs 'open loop' and the Lambda sensor reading is ignored. When the engine is hot, and under load, the exhaust gases probably keep the Lambda sensors hot enough to work properly.
I am wondering if the Lambda sensors are giving incorrect readings when the engine is hot, but lightly loaded.
If it wasn't for the 0155 code I would wholeheartedly agree that it was crank sensor but now I am not so sure :-/
