Author Topic: Speedo Signal..  (Read 843 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
Speedo Signal..
« on: 24 February 2011, 20:12:27 »
Where does the speedo pick its signal up from?
Is it a sensor or from the gearbox?
Ta.
Re: Speedo Signal..
« Reply #1 on: 24 February 2011, 20:17:51 »
abs ecu
Re: Speedo Signal..
« Reply #2 on: 24 February 2011, 20:18:57 »
Neither ...  :)
Gets it from the ABS sensors to the ABS ECU then onwards to the main ECU then the instrument.
One of the classic symptoms of an ABS ECU failure is an intermittent speedo as well as ABS /TC lights  :)
Re: Speedo Signal..
« Reply #3 on: 24 February 2011, 20:41:04 »
Blue wire with a red trace just in case you've accidently cut one :-/
P6UL K
  • Dartford, Kent
Re: Speedo Signal..
« Reply #4 on: 24 February 2011, 21:05:51 »
Al, you've made my evening!  its the same colours as the loom i have in front of me  :y  :y  :y
