Pages: 1 [2] 3  All   Go Down
Author Topic: How Hard Is It To Change Front Wheel Bearings?????  (Read 3891 times)
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
Re: How Hard Is It To Change Front Wheel Bearings?????
« Reply #15 on: 24 February 2011, 21:09:22 »
I'm not sure if its the correct picture as I borrowed it from ebay, But its listed as the front 5 stud bearing carrier + abs sensor
http://cgi.ebay.co.uk/OMEGA-O-S-5-STUD-HUB-BEARING-CARRIER-ABS-SENSOR-94-03-/110609254217?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19c0d34749
Is that what you`re buying
Yes!!! :-?
  • Auckland
    • Mazda MPV
« Reply #16 on: 24 February 2011, 21:18:42 »
Hub nut is 320 nm so will need holding very firmly to undo if off the car!
Apart from that st easy enougj to do on the front.
Is that to change the complete hub as in the pic??
If you swap hubs assembly as pictured with baring assembly attached you'll need to re set the camber. Better to remove the baring assembly by undoing the 320 mill nut and swap just those... Unless theres a problem with the hub assembly?.
There is some possible confussion with terminology here.
Baring is pressed in to the metal flange bit the wheels bolt to. It comes as one bit, so thats the baring in its own assembly imo.
Thats bolted to what i call the hub assembly and holds the caliper/wheel and baring/shock in place...
To swap, the shock has to be removed and therefore the camber setting will be lost.
Hope i've described that clearly  :-/
I don't know the history of this car but the camber setting is probably wrong anyway ::)
I would swap the whole hub + stub axle assembly and then go to WIM to have the suspension set up properly.
[edit]or (as Glasgow is even further from Chesham than I am) I would do what I did earlier this year and use a 6 foot straight edge and a roofers square to measure and set the camber manually[/edit]
« Last Edit: 24 February 2011, 21:22:58 by andyh »
« Reply #17 on: 24 February 2011, 21:25:05 »
Yes!!! :-?
Could be years old. Complete new hub is only about £40, for the sake of £15..........
Jim
  • Glasgow
« Reply #18 on: 24 February 2011, 21:26:22 »
I'm in Gloucester working at the moment.
Jim
  • Glasgow
« Reply #19 on: 24 February 2011, 21:30:09 »
Yes!!! :-?
Genuine Part???
As I asked the local dealer yesterday and was quoted over £100 trade
« Reply #20 on: 24 February 2011, 21:30:44 »
http://www.buypartsby.co.uk/
Front wheel bearing kit is CDK603 app. £40 inclusive
Contitech......decent brand :y
Don`t think they`re listed on website. Phone number for mail order is 0115 9835280
« Last Edit: 24 February 2011, 21:31:26 by RobG »
« Reply #21 on: 24 February 2011, 21:32:18 »
Yes!!! :-?
Genuine Part???
Probably sussed out you`re north of the border ;D ;D
Jim
  • Glasgow
« Reply #22 on: 24 February 2011, 21:34:53 »
Yes!!! :-?
Genuine Part???
That was in Gloucester
« Reply #23 on: 24 February 2011, 21:36:03 »
Yes!!! :-?
Genuine Part???
Your accent ain`t
Jim
  • Glasgow
« Reply #24 on: 24 February 2011, 21:39:34 »
Yes!!! :-?
Genuine Part???
Your accent ain`t
True, the guy behind the counter was alright he gave me trade discount on the thermostat I bought
« Reply #25 on: 24 February 2011, 21:42:22 »
Still wouldn`t go for that 2nd hand hub though :P
Jim
  • Glasgow
« Reply #26 on: 24 February 2011, 21:48:32 »
True, it's just that I'm passing there tomorrow, so I could have checked it out first as the front bearing is started to grind.
« Reply #27 on: 24 February 2011, 21:52:55 »
Won`t have a decent idea of any bearing wear until it`s actually mounted on the car
« Reply #28 on: 24 February 2011, 21:58:57 »
My way was the easiest. Buy hub from dealer & then pay local garage to fit it.  ;) ;) ;)
Jim
  • Glasgow
« Reply #29 on: 24 February 2011, 22:01:26 »
How much was the parts??
Pages: 1 [2] 3  All   Go Up
