Author Topic: Cold air ?  (Read 818 times)
Norwegian.Omega
  • Norway
Cold air ?
« on: 25 February 2011, 00:37:50 »
Hi, i've have an omega b 2.0 16v (No Air conndition)
And i have a problem that i could not get hot enought air flow in the car,
while i driving the engine temp are around 90-95,
It come a little bit hot air, but it's not good enought to get it "comfy"
Does any have some tips to share =)?
Thanks for all comment's and tips  :y
damon80
  • Wigan
Re: Cold air ?
« Reply #1 on: 25 February 2011, 01:08:11 »
When the engine is up to running temperature, feel the water hoses to check they're hot.
Also, check the hoses at the back of the engine which run into the heater matrix - check they feel hot too.
May be worthwhile bleeding the system - run the engine with the coolant cap off, and "burp" (or squeeze) the hoses to get rid of any airlocks.
If that doesn't work, it may be time to flush out your coolant system - there's a "How To" in the Maintenance Guide section of this forum  :y
