Author Topic: Cam cover gaskets  (Read 1984 times)
Xenon
Cam cover gaskets
« on: 25 February 2011, 16:06:26 »
I'm doing the cam cover gaskets tomorrow. I've just read the guide, would it hurt to put the black sealant on all of the gasket?
Re: Cam cover gaskets
« Reply #1 on: 25 February 2011, 16:07:08 »
Only needs to go where specified
mkirky
  • Cheshire
« Reply #2 on: 25 February 2011, 16:26:52 »
Follow the guide and you will have no problems with leaks in a few weeks time make sure you use VX gaskets
« Reply #3 on: 25 February 2011, 16:36:03 »
Using sealant all around the gasket increases the chances of it getting into an oil way and gumming it up, and it makes it a mare to clean off at a later date.
Fit them as per the guide, you won't go wrong :y
Xenon
« Reply #4 on: 25 February 2011, 16:52:23 »
Yes I've got genuine GM gaskets, thanks for the advice, I'll fit them as per guide. :y
« Reply #5 on: 25 February 2011, 16:53:02 »
Make sure you use a torque wrench as well ;)
Xenon
« Reply #6 on: 25 February 2011, 16:59:07 »
« Reply #7 on: 25 February 2011, 17:20:59 »
I did mine last year and 10000 miles later one of them is leaking again.  If I remember right I gave it all a smear thinking it wouldn't do any harm.  Maybe it did!  :(
« Reply #8 on: 25 February 2011, 18:48:33 »
Mine were replaced when the HG was changed at around 135k, and that must be 3yrs/40k ago
They only need doing again because the cam covers have been on and off so many times in the past 12 months without renewing them ::)
Xenon
« Reply #9 on: 25 February 2011, 19:11:04 »
Does anyone know what size torx I need? So I can see if I have them now :)
« Reply #10 on: 25 February 2011, 19:18:27 »
not without checking. E10 or E12 as a guess.
You MUST use a 8Nm torque wrench. Guessing WON'T work (for long, anyway)
