Author Topic: power sounder!!  (Read 1001 times)
ianboyo
  • Somerset
power sounder!!
« on: 25 February 2011, 19:03:42 »
all the news about power sounders i might remove mine just wondering if thats ok to do so will it stop the alarm working properly and will it go off when i remove it or if i put keys in ignition same operation as taking battery off will that stop is going off ect.. can any one help on this procedure thank you  :)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: power sounder!!
« Reply #1 on: 25 February 2011, 19:15:54 »
I don't know whether it was coincidence, but I used the ignition off/disconnect within 15 secs as per battery removal, when I removed mine, and it did not go off. HTH :y
Tony H
  • liverpool
  • Black Elites are luurvley
Re: power sounder!!
« Reply #2 on: 25 February 2011, 19:21:20 »
The alarm will still work sounding the horn only with the power  sounder removed. Follow advice in previouse post to prevent sounder going off during removal if you can't be arsed when it goes off just press the door open button on your key fob :y
« Last Edit: 25 February 2011, 19:29:09 by Tony_H »
