Author Topic: Towbar fitting cost?  (Read 1788 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« on: 24 February 2011, 18:16:00 »
Good evening all,
Anyone know what the going rate is to have a towbar fitted please? Just laid my hands on one from a trusted member of this forum  :y
Just need to have it fitted. Going to see my local mechanic, but just wanted to see what kind of pennies it's going to cost.
TIA   ;)
AKA - Mr Bracket
Re: Towbar fitting cost?
« Reply #1 on: 24 February 2011, 20:55:08 »
Good evening all,
TIA   ;)
There's only 9 bolts bolting it down, dead easy to fit yourself. The hole positions are pre-marked with a dimple so you don't even need to do any measuring.  :y
Ask at a local towbar fitters, it shouldn't be tt expensive, they're most likely to get the electrics right too.  ;)
« Last Edit: 24 February 2011, 20:56:49 by Andy_B »
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 24 February 2011, 22:07:47 »
Yes, a doddle to fit, and if it's a genuine GM towbar, there will be a plus on the wires for easy connection.  :y
p.s. This towbar IS a Facelift one I assume?   ::)
« Last Edit: 24 February 2011, 22:08:59 by Agemo »
blackviper90210
« Reply #3 on: 24 February 2011, 22:13:16 »
Hi Agemo, no it's for my mini facelift estate. I've got a Witter bar to on. Spoke to my local mechanic tonight and quoted me £50 fitted.
Doesn't sound bad?  :)
AKA - Mr Bracket
« Reply #4 on: 24 February 2011, 22:18:08 »
Inc electrics? If not, and as your car already has a bar fitted which means no drilling required sound a bit much. I paid a local towbar fitter £20 to fit my towbar to my saloon, but I had just bought the towbar from him. Then I fitted the electrics. That was probably 5 or 6 yrs ago.
« Reply #5 on: 24 February 2011, 22:54:58 »
Its not a bad price considering he's got to drop the exhaust on the estate, I wonder if he knows  ::)
« Reply #6 on: 24 February 2011, 23:07:34 »
Ah! I've never looked at an estate's.  ;)
blackviper90210
« Reply #7 on: 25 February 2011, 07:09:00 »
The price was for fitting and electrics! Not had one on the estate before as only just got it, but do have one already on the saloon.
Gonna have a look today and see how much of the work I can do. Not that savvy on cars, but always willing to look and have a go, providing it's not a safety related part, ie brakes etc  ;D
AKA - Mr Bracket
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #8 on: 25 February 2011, 12:18:00 »
quite a bit different, 4 bolts on the left and 2 on the right and as pete says rear box needs lowering for access :y
other rides
« Reply #9 on: 25 February 2011, 12:20:37 »
Bite his hand off in the rush to accept !!! for full (either 13 pin or 12N + 12S) electrics and fitting that is an excellent price .. the electric parts alone will be at least £25 IMHO ...   :)
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #10 on: 25 February 2011, 19:37:30 »
Yes, the socket etc was a rip off from the stealers so I soldered straight in. Seem to remember the only issue was I had a choice of 3 wires for one of the colours and got it wrong the first time. Other than that, just follow the guide on here.
Work is the curse of the drinking classes (Oscar Wilde)
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #11 on: 25 February 2011, 20:08:00 »
Oooerrr...., I put my estates towbar on myself, but didn't need to drop the exhaust??  I just wiggled the plates into place, supported the bar on a trolley jack (means you are able to lift/drop and manoeuvre it into the right place easily) and just needed a spare pair of hands (son!!) to hold the socket on the bolt whilst I did up the nuts underneath.
Worst bit was ensuring all the spacers were in position before putting bolts through the holes in boot floor/chassis.
Whole job including wiring in single electrics was just under 2 hours, and only needed help with the bolt/nut tightening... :y
I always knew I'd inherit an estate, but I never thought this would be it!
