Author Topic: airbag removal, cant take battery off  (Read 1303 times)
doug4293
  • greenock, scotland
« on: 24 February 2011, 22:50:15 »
i need to take air bag out to get into the heating duct to put it back together (from the middle blower bit to passenger side) thing is i cant take battery off as il loose radio as i dont have the code, the whole passenger side vent is out and theres an orange connector plug, can i disconnect that, take the airbag out, fit the heater ducting and refitt airbag and connect it ? or is thre a fuse i can take out, obv i will not put the key in the ignition while i am doing this.
« Last Edit: 24 February 2011, 22:52:10 by doug4293 »
Signature deleted as it's too big.
Re: airbag removal, cant take battery off
« Reply #1 on: 24 February 2011, 22:55:11 »
Unplug anything to do with the SRS circuit whilst the battery is connected and the warning light will come on. Can you not do the heating ducting with the glovebox out
« Last Edit: 24 February 2011, 22:55:38 by RobG »
doug4293
« Reply #2 on: 24 February 2011, 23:06:14 »
i cant get my ha up into it to connect it to the plastic bit it connects to :( if i do unplug at and the srs light comes on, how is this reset ?
« Reply #3 on: 24 February 2011, 23:11:26 »
Unplug anything to do with the SRS circuit whilst the battery is connected and the warning light will come on. .....
you sure? :-/ I'd suggest it only triggers the airbag light if the ignition is switched on with a SRS bit disconnected ...................... obviously it's a better/good idea to disconnect the battery though.  ;) ;)
« Last Edit: 24 February 2011, 23:11:52 by Andy_B »
« Reply #4 on: 24 February 2011, 23:13:16 »
.... if i do unplug at and the srs light comes on, how is this reset ?
You'd need a code reader of some sort, either a real Tech II or a 'Cheapo Tech II'  :y
« Reply #5 on: 24 February 2011, 23:20:52 »
Correct. The only power source to the SRS ecu is ignition switched, so turn off the ignition and leave it turned off until everything is back together and wired up and you will have no problem. :y
doug4293
« Reply #6 on: 24 February 2011, 23:23:50 »
okay il give it a try thanks,il keep youz posted !
doug4293
« Reply #7 on: 25 February 2011, 23:56:02 »
goin to try this tomorrow, is there a fuse i can take out for thee airbags also ?
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #8 on: 26 February 2011, 00:43:02 »
doug
no need to take any fuse out just do as as the others have posted do not under any circumstances turn the ignition on until everything is back together
