Author Topic: CAT TYPE APPROVAL  (Read 996 times)
Glyn
  • Essex
    • 2.2 CDX Estate
CAT TYPE APPROVAL
« on: 27 February 2011, 11:50:30 »
Hi
I need a new front exhaust section.
I have noticed that there are two types, pre 2001 non type approved, and post 2001 type approved about £50 more. Is there any practical reason I cannot put a non type approved on?. eg different size, poor running, mot testers will fail it.
 Glyn
Re: CAT TYPE APPROVAL
« Reply #1 on: 27 February 2011, 11:51:38 »
Non geniune cats are horrid.
As you have a 2.2 (assuming its petrol?), is it the exhaust flexi, which is just after the second cat which has split/failed? If so this can be cut off and replacement put on, part is just £15  :y
« Last Edit: 27 February 2011, 11:52:00 by tunnie »
Glyn
  • Essex
    • 2.2 CDX Estate
« Reply #2 on: 27 February 2011, 12:00:41 »
Yes it is the flexi.
Any idea where to get one?
Also do they have to be welded on?
Cheers
« Reply #3 on: 27 February 2011, 12:06:46 »
Yes it has to be cut out and replacememt welded in:
http://www.camskill.co.uk/products.php?plid=m15b0s1411p5644
If you find a good stainless steel zorst place, they maybe able to do it without dropping the exhaust.
If you know a mate with a welder, you can easily drop the exhaust from the manifold...
« Last Edit: 27 February 2011, 12:07:41 by tunnie »
