Author Topic: Omega Diff Differences  (Read 2561 times)
omegabsw
  • Essex
« on: 27 February 2011, 18:51:35 »
Regardless of LSD, Is anything different about the diffs that come standard on the Omegas across the range?
Would a 4 cylinder diff fit a V6 and vice versa?
« Last Edit: 27 February 2011, 18:51:48 by omegabsw »
Re: Omega Diff Differences
« Reply #1 on: 27 February 2011, 19:04:03 »
have a look in your Haynes manual  ;) There are at least differences between auto & manual, but the ratios are given in Haynes. :y
omegabsw
  • Essex
« Reply #2 on: 27 February 2011, 19:12:40 »
Yeah, I knew that there would be differences in ratios between auto and manual but 4 cylinder and v6 if both were manuals?
Alas I have no Haynes manual  :'(
Library it is then, unless someone wants to have a look for me please
« Reply #3 on: 27 February 2011, 19:17:22 »
you want me to get my bum out of this big comfy arm chair don't you.  ;D ;D ;D
omegabsw
  • Essex
« Reply #4 on: 27 February 2011, 19:18:46 »
As you offered :-*
« Reply #5 on: 27 February 2011, 19:20:40 »
« Last Edit: 27 February 2011, 19:20:57 by RobG »
omegabsw
  • Essex
« Reply #6 on: 27 February 2011, 19:23:23 »
Facelift ratios here http://www.omegaowners.com/forum/YaBB.pl?num=1163895469/0#0
Thanks, I didnt even have to beg to you like what Andy was making me do.  ;D
« Reply #7 on: 27 February 2011, 19:24:29 »
Right ..........
(Mr Haynes only does pre-facelift cars)
Up to 1998
All 2.0 ............  3.9:1
2.5 manual....... 3.7:1
2.5 auto .......... 3.9:1
3.0 manual ...... 3.7:1
3.0 auto .......... 3.7:1
From 1998
all 2.0 .............. 3.9:1
2.5 manual ....... 4.22:1
3.0 manual ....... 3.7:1
3.0 auto ........... 3.9:1
« Reply #8 on: 27 February 2011, 19:26:31 »
Bugger!  ;D
What kept you Rob?
omegabsw
  • Essex
« Reply #9 on: 27 February 2011, 19:29:03 »
Right ..........
Up to 1998
From 1998
OK thats really strange, the later 2.5 manual's having a 4.22:1 final drive but as per Rob's post it says that 2.6's have the 3.9:1 ratio.
« Reply #10 on: 27 February 2011, 19:37:58 »
Right ..........
Up to 1998
From 1998
It does stand out a little from the other ratios .......  :-/
