Author Topic: Memory seats  (Read 1231 times)
SMD
  • London
    • :( nowt
Memory seats
« on: 27 February 2011, 12:57:20 »
I cleaned my drivers seat today and as you do, moved the seats in all different positions to get to every bit of leather.
When I finished the seat wouldnt return to my preset position. I spent over a month trying to get comfy!  :(  This was all with the ignition off.
Re: Memory seats
« Reply #1 on: 27 February 2011, 13:01:32 »
.......When I finished the seat wouldnt return to my preset position. I spent over a month trying to get comfy!  :(  This was all with the ignition off.
Won't go forwards enough? Coin stuck in the runner?
SMD
  • London
    • :( nowt
Re: Memory seats
« Reply #2 on: 27 February 2011, 13:48:48 »
Dont think its a coin because everything works manually and:
1. I'm skint and dont have any money in my pocket  :(
2. I only set this position yesterday and it returned to it after changing it slightly.
The back doesn't come forward enough for a start and everything else is slightly out from how I would like.  Just tried it with the car started and no change.
« Last Edit: 27 February 2011, 13:49:44 by SMD »
Re: Memory seats
« Reply #3 on: 27 February 2011, 15:02:05 »
I used to have a problem with my passenger mirror. If i pressed 1 to my presets it would all go to where it should, but if I pressed 1 again, my passenger mirror would tip down.  :-? It fixed itself when I had the mirror off. maybe cleaned contacts in the plug as i unplugged & plugged it back in. Maybe there's a dodgy connection somewhere  :-/  :-/
SMD
  • London
    • :( nowt
Re: Memory seats
« Reply #4 on: 27 February 2011, 22:04:05 »
Oh well, lost the comfy seats for good then.  :-[  To make matters worse, the seat is still not that much cleaner  :(
