Author Topic: omega boot release  (Read 1764 times)
vomega51
  • east london
omega boot release
« on: 22 February 2011, 21:33:31 »
hi, my boot release will work off the key but not of the dash switch, any suggestions would be appreciated
Re: omega boot release
« Reply #1 on: 22 February 2011, 21:35:00 »
you doing it with ignition on? It won't work, late 2002 it was updated to work with 3/4 second push. Earlier versions only worked with the key removed.
Checkout hilpers boot mod in the maint section, its a guide on how to make it unlock with ignition/engine on
V6 CDX-er
  • Sheffield
« Reply #2 on: 22 February 2011, 21:36:02 »
With the engine running (and maybe the vehicle in park with handbrake on?), you need to hold down the button on the dash untill the boot opens. I cant remember if it is for 3 seconds or five?
How long are you holding the button down for?
V6 CDX-er
  • Sheffield
« Reply #3 on: 22 February 2011, 21:36:44 »
Dam Tunnie beat me to it by a minute. :(
vomega51
  • east london
« Reply #4 on: 22 February 2011, 22:34:24 »
cheers guys, :y :y, will take your advice onboard and will try again in the morning :)
davethediver
  • Blackburn, Lancs.
« Reply #5 on: 22 February 2011, 23:16:36 »
And push and hold the button in for a few seconds not just a quick press :y
EDIT ~ Read above replies properly :-[ :-[
« Last Edit: 22 February 2011, 23:17:45 by davethediver »
P.A. Caron de Beaumarchais
Lesopc
  • West London
  • Worlds Biggest GM Fan
« Reply #6 on: 23 February 2011, 15:52:40 »
As above, it depends on year as it was changed in 2002. Models from 99-02 had a kind of interlock which required that the key was removed from the ignition before either the dash button used or the keyfob used???
Why oh why was there never a V8 Omega????
Such a missed oppurtunity.
Look forward to the Cadillac ATS & ATS-V. Maybe a re-badged one will replace the Miggy as a RWD runner?
Tangerine
    • 6-2000 2.5TD Auto CDX
« Reply #7 on: 26 February 2011, 00:11:07 »
Is there a suggestion here that a mod can be made to allow the earlier version to open the boot with the engine running.  I would be quite happy if the handbrake needs to be on etc.  I have been unable to locate the article from the information given.  Can anyone please supply a link or what to search for - thanks
« Reply #8 on: 26 February 2011, 00:19:01 »
Known as the "Hillpers" mod ..
http://www.omegaowners.com/forum/YaBB.pl?num=1155211091
Tangerine
« Reply #9 on: 28 February 2011, 09:41:48 »
entwood
Thank you.
Page created in 0.026 seconds with 20 queries.
