Author Topic: Fault code  (Read 1134 times)
flyer
  • Telford Shropshire
Fault code
« on: 26 February 2011, 22:48:46 »
Just managed to have fault code read on my estate P1781 has anyone an idea what it means. :(
Re: Fault code
« Reply #1 on: 26 February 2011, 22:56:40 »
That code`s not applicable to the 2.2. Possible dodgy cam sensor
flyer
Re: Fault code
« Reply #2 on: 27 February 2011, 19:12:42 »
thanks for that. the guy that read it gave me that one have a fault with the gear box he said it may be a problem with the engine ecu communicating with the auto box ecu any ideas
                Regards Flyer
Re: Fault code
« Reply #3 on: 27 February 2011, 19:17:14 »
                Regards Flyer
As said......not applicable to the 2.2. Any symptoms with engine or box?
flyer
Re: Fault code
« Reply #4 on: 28 February 2011, 10:01:00 »
Problem with auto box changes up fine to third then engine revs  but box is in neutral ease foot off and the gear goes in but with a jolt, sometimes changes as normal then again it may go into limp mode.
davethediver
  • Blackburn, Lancs.
Re: Fault code
« Reply #5 on: 28 February 2011, 16:53:11 »
Would have a check of your ATF level and as Rob said maybe dodgy cam sensor well known on the 2.2 for throwing up random codes :y
P.A. Caron de Beaumarchais
