Author Topic: Manual conversion  (Read 3776 times)
2woody
  • Northumberland
Re: Manual conversion
« Reply #15 on: 28 February 2011, 09:23:14 »
the mod is all to do with the ECU recognising if it is fitted to a manual car or an automatic. The wire itself is nothing to do with the timing retard.
It's all about making the car easy to build for Opel. The ECU has both sets of internals for both gearboxes and once installed on the production line, the presence of an earth on the line in question tells the ECU which type of transmission is fitted.
the ignition retard is applied during the gearchange on the auto only, to reduce the power a bit and therefore make it a smoother gearchange. Not required on a manual.
Shane mvsex
  • maidenhead
    • 3.0 pfl mv6 caravan
« Reply #16 on: 02 March 2011, 18:24:09 »
The car is all back together now went to start the car and nothing, have all the ignition lights come but nothing on the turn of the key. Now the starter inhibitor switch wires are they the wires from the gearbox side or the wires inside the car? If inside the car they are conected if the wires at the gearbox end then these need to be sorted, so would this be the cause of the non starting?
 All the plugs are connected to the relevant sockets so no problems there just this non starting problem.
  All help is appreciated.
migs and rc helicopters yeeeehaaaaaaa!
Www.omegaowners.com
Www.omegaownersnetwork.com
2woody
  • Northumberland
« Reply #17 on: 03 March 2011, 16:25:31 »
have you taken the auto wiring out of the engine bay ? that's the stuff in the third large connector adjacent to the battery.
that's probably the best place to bridge the starter wires.
Shane mvsex
  • maidenhead
« Reply #18 on: 03 March 2011, 19:00:26 »
we sorted that from underneath now.
and she drives lovley and very quick he he he
couple of things to do still. i have no reverse lights even tho we switched the wires over still nothing.
tc lights on and we need to cut pin 42 and join it to a brown wire hopefull that will cut out the tc light and maybe the reverse lights will work....
i dont really have any pictures but i will post up some up that i do have in the gallery and here
thanks for all ur help  :y
Www.omegaowners.com
